FS: 951 - 16v 2.8L 6-sp Nautic Blue
Cold start sounds a lot like when I had my cycling valve removed while waiting for a new one. The old cycling valve was a source of vacuum/boost leak. There was a thread not too long ago about the drivers (transistors in the DME) for the cycling valve going bad and how to replace them - bad drivers would give similar cold start issues I believe. Just a thought...
I agree, ISV issue. could be the motor and if not, likely it is the DME transistors. this is the thread
https://rennlist.com/forums/944-turb...n-the-dme.html
Do you have the late style VR sensor bracket with shielded shaft? If not, this could be the cause.
Hey Jonathon! Hope all is good!
Someone buy this car. We Nautic Blau guys need to keep this car in the family!
Pic of mine! Good luck! If I had the cash, I'd take it off of your hands ASAP. 16V 2.8 is a pretty cool setup!
Obligatory pic of mine...but yours looks better!
AGAIN! Someone buy this thing!
