advice
advice
i found an 87 944s with a blowen motor on craigs list yesterday. i was looking for kinda of a buyers guide but havent found anything. can you guys kind of tell me what things i should look for. what gos bad on these cars. what can get really expensive. when to walk away from it. maby to how like is with these cars. are theyll reliable or are they brakeing down all the time. do they drain your wallet when they do brake. any help would be great. thanks
Blown motor doesnt tell us much
Did the timing belt break, Cam tensioner pads break
I dont see many "S" heads for sale so i believe finding a good one might be a problem.
The regular 944 heads are more available
Its an old german car so they are cheap to buy but expensive to maintain. Good luck on your search.
I believe everyone on a 944 forum is going to say "it's the BEST Car ever", what sets this forum apart is, we're telling the truth. Not the most HP, not the fastest, not the most inexpensive, not the most spacious, not the most luxurious, but, it IS the best Drivers Car for the buck.
Starting with a basket case is not recommended eather, the learning curve for a high tech Euro Sports Car require's some experience to avoid the pitfalls, the level of Design and Engineering takes some getting use to, especially if you only have domestic experience. Find one that was Loved, usually around $5k for a NA, = Normally Aspirated, then have a Pre Purchase Inspection done at a Porsche Shop. Better to learn about these Cars as you drive them, then to contemplate the mysteries from the wrong side of a Trouble Light.
btw, example, these Engine's have a Cylinder Coating for looooong life, you or your basic Machinist can't touch that.
the guy didnt post up much info. im trying to contact him now to get the whole story. ive already found a new motor for 1500 bucks. ive curently have a vw golf 337 so i have a small amount if experince with germans and all there one off tools. thanks
Yeah dont buy a motor that you havent heard running. Assume anything you buy will need to be rebuilt. I wouldnt pay more than 300-500 for an NA motor Never priced an S motor. Turbo motors go for 800-1k
I'd say stay away unless you're a fool with money. With these cars it's generally better to pay a little more upfront for a good example than to buy a basket case that needs $5k in work just to make it reliable.
