help with rebuild wire harness
Old 03-11-2013 | 08:31 PM
Diazpa's Avatar
Diazpa
3rd Gear
Default help with rebuild wire harness
what will i need to rebuild my wire harness for 86 951 i need sort of list so i know what i should purchase
Old 03-11-2013 | 10:14 PM
Scott H's Avatar
Scott H
Just the engine bay harness? You have a few choices, first you can buy all the connectors and hope that your wire is all good. Connectors can be found at http://944online.com/cgi-bin/ASI_Sto...ector-944turbo
Your other choice: Lindsey Racing sells harnesses that replaces the connectors and wires up to the DME, everything is pre-terminated with the exception of two solder joints. See here: http://www.lindseyracing.com/LR/Parts/HARNESS.html
Old 03-12-2013 | 01:10 AM
refresh951's Avatar
refresh951
Couple threads that may help:
https://rennlist.com/forums/924-931-...s-rebuild.html
https://rennlist.com/forums/944-turb...b-project.html
Old 03-12-2013 | 03:51 AM
Diazpa's Avatar
Diazpa
3rd Gear
yes just engine bay the wire are all fried falling apart
Quick Reply: help with rebuild wire harness
