Help ID turbo k26 cheater? Turbo connoisseurs
Basic Sponsor
Okay I received the below unit as a trade for some parts it was supposed to be a k26-6, but upon inspection I found that the turbine wheel inducer was 64mm and the exducer 54mm, according to some factory data the k26-6 turbine inducer is 64mm but the exducer is 48mm, I took some measurement and compared it to a another k26-6 turbine and indeed this unit exducer is bigger, did I score a rebuilt k26-6 cheater?
TIA
lart
see pictures below 1 & 2 new unit 3 & 4 k26-6 stock
pictures 5-8 unit in question
TIA
lart
Basic Sponsor
the k27-6 dr is set up similar. The 6 hotside is machined out to fit the 8 wheel. So in essence the dr is a k27-8 with a 6cm turbine housing.
If the compressor wheel is a stock k26, then what you have is a cross betwen the 26-6 and a 26-8. probably acts just a little better than a 26-6.
Have you measured the compressor wheel? That may be modified too..
Basic Sponsor
10 years ago when you were probably in elementary school, Huntley racing came out with some cheater k26-6, designed for club racers, the stock look with extra added power, I believe big John from Texas pushed 330 rwhp at 22 psi with a cheater turbo, of course that's nuts but there is some minimal but gain after all
Basic Sponsor
Basic Sponsor
Basic Sponsor
