Cam timing info
Old 01-21-2013, 09:28 PM
eman930
eman930's Avatar
Josh what kinda effect would this have with a M-tune setup??
Old 01-21-2013, 09:43 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
What are you specifically looking to have answered? My 951 runs my off-the-shelf M-Tune setup (with full tuning and logging obviously).
Old 01-21-2013, 09:54 PM
eman930
eman930's Avatar
Just wondering if this would be a good little boost in power, I plan on getting the M-tune with the injectors soon, I'm thinking this combo at 18/20psi, and the offset key to help midrange would really wake the car up
Old 01-21-2013, 10:28 PM
Rogue_Ant
Rogue_Ant's Avatar
Well, I run it in my own car... so that should tell you that I liked the results
Old 01-21-2013, 10:35 PM
zerMATT951
zerMATT951's Avatar
Joshua, do you run the 2 or 4 degree key?
Old 01-21-2013, 10:59 PM
Rogue_Ant
Rogue_Ant's Avatar
Um, well in the 951 I actually run a fully adjustable gear set to 3° advance. In the 944NA I run the 4° key.
Old 01-21-2013, 11:02 PM
eman930
eman930's Avatar
Do you think 4 degrees is too much? What made you pick 3?
Old 01-22-2013, 12:19 AM
Rogue_Ant
Rogue_Ant's Avatar
4° is fine. I picked 3° on the 951, because that was in-between what I have tested in my 944NA. So, I was just trying to get another "data-point" for my own knowledge.
Old 07-03-2013, 01:42 PM
Quickbeam
Quickbeam's Avatar
Stumbled across this thread during a search. Would one tooth on the cam gear be 4.5 degrees? 40 teeth on the gear, 360/40 = 9 but the cam gear spins only 1/2 turn per engine rotation. Am I thinking about this right?
Old 07-03-2013, 01:48 PM
User 52121
User 52121's Avatar
Hey fast924S - got any impressions on the outcome of the cam key?
Old 07-03-2013, 04:58 PM
Duke
Duke's Avatar
My advice is to only adjust this on the dyno. Almost impossible to determine the best cam position on the street. While advancing the cam can give better low-end it can also make the already steep torque fall off at high rpm on the 8v take a dive much earlier in the rpm range. So the total effect can be a slower acceleration car even though boost comes on earlier.
Old 07-03-2013, 05:06 PM
Reimu
Reimu's Avatar
I've had the 4 degree advance key in (actually I advanced the cam one whole tooth and then flippped the key around to retard, my head has been shaved a few times so I assume this will get me the true 4 degree) fr a while and I never really noticed a change. I agree that this is one of those things that needs to be done on a dyno. Or at least someone with a stockish car to do a before/after dyno with various timing.
Old 07-03-2013, 05:14 PM
Quickbeam
Quickbeam's Avatar
Anybody know how many degrees for one tooth?
Old 07-03-2013, 05:15 PM
Duke
Duke's Avatar
I found an old dyno chart. Don't remember the exact spec of the engine but I think it was a 2.5l 8v with an N/A cam and GT3582R 0,82 T3 turbo and Link EMS.
I had an adjustable cam gear and tested both 1 deg advance and 1 deg retard. As you can see 0 advance worked best for this engine. Both retard and advance from 0 made everything worse! No gains anywhere.
(The legend colors are switched green/red).
Old 07-03-2013, 05:20 PM
User 52121
User 52121's Avatar
I'm pretty sure Rogue also did his testing with cam timing on a dyno... (?) He'll chime in eventually I imagine.
Quick Reply: Cam timing info
