LS conversions. Let's hear it.
Old 11-20-2012, 12:00 AM
  #106
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
not to mention any weight savings would probably suffer with having to build some kind of heat barrier/venting for the engine in an attempt to keep the cockpit from getting too hot and the driver being poisoned by harmful vapors ? and doesn't the torque tube also add structural integrity to the car/increased safety?
Old 11-20-2012, 12:57 AM
  #107
mikey_audiogeek
mikey_audiogeek's Avatar
Originally Posted by Dubai944
^^ Not true. It would just require some spring rate and suspension changes. By concentrating the weight between the wheel base you would be lowering polar moment of inertia and with the right setup would probably end up with a more responsive handling car.
Not saying a mid engine fit would be easy though, you do have a problem with a lack of driver space, but you could move the rear suspension back or extend the footwells.
They did a mid engine V8 swap for the Alfa Sprint in Australia in the 80s. The sprint body has more room behind the driver for it, but a crazy cool idea anyway.
http://theamazoeffect.blogspot.com.a...lian-body.html
Ah, the Giocattolo, one of my all-time favourites. Brilliantly designed and executed, shame the cost of the gearbox nixed it.
If I recall correctly, the project was funded by the import credits earned by exporting Ford 351C engines to De Tomaso!
There's a sadly awesome photo sequence of someone in one trying to break a Vmax record and hitting a wall.
Old 11-20-2012, 01:52 AM
  #108
Dubai944
Dubai944's Avatar
Originally Posted by LS1Porch
Are you really concentrating the weight between the wheel base, or just loading it all on the rear? If you look at the Alfa you posted, they actually put the weight between the wheel base.
Either way, the rear suspension would be a nightmare. I'd rather shift the engine back in the engine compartment, moving the firewall if needed, to achieve the same effect.
If the weight is in front of the rear axle line and behind the front axle line its between the wheels, so yes you really would be. I'm not saying it's necessarily a good idea, I am saying doing it would not make the car handle worse which you suggested. Yes it would require some suspension work, but if anyone went to that much trouble to fab up what was required to mid mount an engine, a few changes to the suspension, including moving mounting points would be simple to include in the work.
Even the stock rear suspension design would work no better or worse as long as the spring rates matched the weight increase and bushings joints were beefed up where needed, but you might as well fab in a double a-arm rear while you are cutting the car to pieces.
A lot of the cars running in our Sports Sedan category move the whole engine and gearbox rearward by cutting the firewall to achieve a front mid engine. The fab work involved in that is just as complicated as it would be to mid mount something. And you aren't achieving quite the same effect as a rear mid engine. A rear weight bias is still superior for acceleration and braking.
Plenty of cars are setup with drivers only inches away from the engine. Firewalls and insulation are not that heavy. The torque tube only adds rigidity to the drivetrain which is lost by having the engine and gearbox so far apart in the first place, not to the car itself. Getting rid of the weight would be a win.
Old 11-20-2012, 04:09 AM
  #109
333pg333
333pg333's Avatar
How about reversing the whole drivetrain. Engine in rear, gearbox in front and shorten the torque tube...
...I kid I kid...
You could make it 4wd though. That would put some weight back in the front. Pull an Evo drivetrain out and run the mid engine East-West...now this is getting silly.
Old 11-20-2012, 04:13 AM
  #110
Dubai944
Dubai944's Avatar
Or turn the driver around to face out the back window?
Old 11-20-2012, 04:18 AM
  #111
333pg333
333pg333's Avatar
...or with those old Spy Glasses you could buy from the back of Comic Books that had tiny mirrors in the corner of the frames to see behind you....just saying...
Old 11-20-2012, 04:34 AM
  #112
alxdgr8
alxdgr8's Avatar
Mythbusters 928-style
Old 11-20-2012, 09:36 AM
  #113
xschop
xschop's Avatar
The Audi V8 is 396 Lbs dry and if mated to the 944/951 trans would have the serpentine only 10.5 inches forward of the torsion tube. That's what I've measured anyways.
Someone is actually mounting the Audi V8 in the front bay on 944hybrids.
Old 11-20-2012, 01:56 PM
  #114
Thom
Thom's Avatar
I stumbled upon this on the 928 board :
http://www.youtube.com/watch?feature...v=Cx34NK1yB3M#
http://www.pureperformancemotorsport.com/cars.php?id=26
Ever seen this car up close, Duke?
Old 11-20-2012, 02:42 PM
  #115
Duke
Duke's Avatar
I've seen that car once but didn't get a chance to scrutinize it. It didn't look so nice from what I could see but then again race cars tend to look like crap after a while.
So I don't know how much they've modified to get the 928 V8 in there.
Old 11-20-2012, 04:31 PM
  #116
mikey_audiogeek
Good points.
If we're not careful, this will end up as pointless a discussion as those about putting Honda drivetrains in a BMC "mini". I put "mini" in quotes because it sorta defeats the purpose, why not keep the Honda drivetrain in the Honda?
Anyone wanting a mid-engined Porsche should just buy a 904, Cayman, 914 or Boxster (in that order...)
Of course, I'm not considering the "cool" factor. A mid-engined 944 would be sorta cool!
Cheers,
Mike
Old 11-20-2012, 04:38 PM
  #117
Duke
Duke's Avatar
The 944/968 may have many faults, but not sure I would agree that the engine and transaxle layout is one of them....
Old 11-20-2012, 06:21 PM
  #118
Dubai944
Dubai944's Avatar
Personally, if I wanted to change the basic layout I would just buy a different car. Still, fun to think about the alternatives.
Discussing crazy ideas like mid mounted Audi engines does make a point though. There is a fundamental difference between the reasons why you would do an engine swap, of any kind, for a road car compared to a race car. For a road car it can be any reason, cool factor, money saving or just the engineering challenge. For racing it has to be clearly justified in terms of maximising performance within the regulations and the budget you have. In most cases developing the stock engine is going make the most sense.
You really have to get your car running again Pat, you are going nuts...lol
Old 11-20-2012, 11:01 PM
  #119
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Nice car, but I seriously doubt 450RWHP. At the crank maybe. Even the 6.5L strokers with tons of mods barely made that kind of power.
TonyG
Old 11-20-2012, 11:55 PM
  #120
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
640-whp-7-litre-928
Quick Reply: LS conversions. Let's hear it.
