Anyone have all the factory under tray stuff?
I have the large connector pc if you need it. $40 plus shipping.
Yes, Cyberpunky has it correct - the aluminum part attaches to the plastic part - and you remove them together as a pair. The plastic piece has 3 bolts that attach to the lower radiator frame (accessible through the holes in the batwing), 5 bolts (IIR) that bolt to the sub frame, and two nuts that hold those little arms on the aluminum piece to the side of the wheel wells (you'll find M6 studs attached to the body there).
You take off the hardware I mentioned above (the batwing will hold up the front and the rear is held on by those aluminum arms on the studs) kind of stand behind it, flex the arms over the studs, slide it back about 2 inches, and its off!
I think the main point of the aluminum part is really to protect the caster blocks from the heat of the crossover and down pipes.
Where did all of the rear pan's go? Do people throw them out? They came on every single 951 produced, right? Why are they so damn hard to find now?
The pans get removed during oil changes and do not get reinstalled. I guess most original owners were paying a shop and never noticed. thankfully mine still has them.
