Godzilla Bov question
#33
Basic Sponsor
maybe the reason of your problem is that you got a Godzuki instead of the Godzilla
#35
I made a custom mount for the sensor to center the element in the tube. Some small changes were made on the smt-6 to dial in the AF's. I occasionally need to clean the element as there is a bit of oil residue in the pipes. Nothing big a small shot of brake clean to clean it off. Works very well and my AF are good across the board. I'm running a custom header 2.5" crossover to a 60-1 hifi with a v-band outlet true 3" downpipe, I fabricated it all myself. I went full t3 turbo about 7 years ago and made the header etc then. I've been on a big frontmount IC for 5 years, a bit ahead of most of us. Unfortunately the car hasn't been driven in almost 2 years, stripped awaiting paint plus I'm enjoying my 968!
#36
Just out of curiosity...how are your vacuum lines? If they havent been looked at for some time or never, that could be adding up with the bov leak. Probably if the only leak was the bov the leak and hesitation would be less severe
#37
Hey guys,
I finally found a way to hook the bov back to the maf pipe without any welding. The hose in between goes under the maf pipe and back to bov. That was pretty much the only space I had left. I did the job with ordinary plumbing suppling from the hardware store and some bit and pieces I had left from tuning jobs. Maybe one day I could bring my system to a welder, but I'll live with it for a while.
There was absolutly no problem with the bov. The sound is great. A bit like my forge, but with a ''flag flapping in heavy wind'' sound.
I would like to thank Jim (lejams) for his support after his sell. He didn't have to, but he helped me all the way. Thanks Jim.
BTW dr. dynamics, my vacuum lines are fine.
It's true, with all the post I read in the last 3 days, that running atmospherically a 944 turbo without a map system will run like crap. If your like me, who wants a steady idle, who need to plug hat bov back in the maf pipe.
Next winter project: My intake looks like crap now with these beautiful pipes, I'll take it off, remove all the paint crap, and polish them.
thanks all for your help.
#38
also, ''yes'' everything looks dirty. Somebody as hit my right side wing months ago, my insurrance paid, went to this shop, and did the sanding with my hood open.
I have an appointememnt tomorrow at 8 so that they will clean my engine bay (for free), with some products and air pressure.
#40
For me, yep it's dirty. Everything that's suppose to black is grey. I tried cleaning all the crap away with engine cleaner, and everything as stained.
I been and working hard on this car, I don't accept gettting my car back from the body shop, with the engine bay covered in primer dust.
#42
Godzilla BOV
This is the correct MAF tree to recycle the boost into the MAF stream when the TB plate closes. I don't know why some people believe that the piston is supposed to be partially open on this on low throttle, the job is for this to open only at your set limit, it's adjustable and if you set the spring to 18 psi it opens at 18 psi and opens quickly. The long pshhhhhh sound is a bad thing this means it's opening s l o w e l y, you want a fast crisp PSH this this means it released the air quickly.The spring in mine is very stiff, requires a lot of push to get the piston to move, I had to back it out a few turns so you have to adjust them but they work great. People who say the Tial 50 mm is faster might not have actually owned Godzilla. It's big but it looks like it means business like a chrome colt .45
