Machined 968 pistons ?.
In the interests of a budget 3.0 build I was wondering how many people had successfully used machined 968 pistons ?. Hartech in the UK did this but as far as I know that car hasn't done a lot of miles. On the plus side they are the correct material and relatively cheap, the minus side I would think removing material from the crown needs to be done carefully and are the rings suitable for forced induction ?.
Probably have thin ring lands too. I wouldn't do it unless you were going for low boost. Then I'd say..what's the point.
After awhile, it's just with it to get the right parts or build something out of the ordinary.
I recently spoke to someone that ran a standard 968 with a supercharger for 4 years, dont know what condition the pistons were in when a rod put holes in the block and sump though.
Yes,
its doable at 6-8psi. David Chen of turbo gruppe did some 968s that way, they are fine if you know what your cc after your done.
Mike
I have a 3.o 8 valve head with valves etc. if your interested too.
Mike
