Collapsed Exhaust pipe
I removed the collapsed sections and will weld the pipe back together. Bought the car early this year. Interested in performance after the blockage removed.
Cross pipe looked good. Used a 1" rubber hose inserted up to turbo. When i tried to push the hose in the cat pipe, no joy. After a few minutes of sawsall the problem was identified.
That's the best picture yet of the infamous collapsed downpipe! Yes, you should feel the difference! Just going from a cat to test pipe is noticeable. I'd take a close look at the cat portion for melting/blockage if you are planning to use it. If you don't need to retain the cat portion, or if a new higher flow replacement will suffice, you'll notice it even more.
Basic Sponsor
I have seen that in both crossover and down pipe.
Drive-by provocation guy
Yea get the cat out at the same time and with the collapsed pipe out you will swear its a whole different motor under the hood. Lol
WRONGLY ACCUSED!
Received 4,052 Likes
Can someone explain how this happens?
Rennlist Junkie Forever
Seen it many times, just not to that degree.
It's commonly known that buying a real test pipe (like a Bursch) makes a much larger difference than just getting rid of the cat. And this is exactly why.
TonyG
TonyG
Also test pipe is test pipe. Be it 3 dollars or 300.
The collapsed down pipe is part of the cat converter. When people hollow-out there cat, they think they are getting the same benefit as a test pipe. Instead, they have a restricted pipe with a partially collapsed inner wall with a nice hollow cat in the middle.
