ehhh weird over boost.
Professional Hoon
with my gtx3076r w .83 ar rear housing, eBoost2 & TiAL 38mm w/g
in 2nd gear i'd rev about ~4000 rpm and put my foot down, even slowly and it will over boost to 20-21 psi. it triggers boost cut on the m-tune and even triggers boost cut on the eBoost (20 psi)
7psi w/g spring and my eBoost 2 is set to open at 12 psi (recommended 3 psi before desired boost pressure) and in 3rd gear it will boost to 17-18 psi but it tapers up from 12 to 17 psi after the wastegate being open.
is my turbo spooling to quick for the eBoost to keep up? or do i need a larger wastegate?
Personally I prefer running higher spring pressures in the wg and using single port. I never have any issues at all. Flat line boost logs. It may spool slightly slower but I don't think so.
1. Regular boost. Lose racee.. Hit high boost button
2. Just barely lose race on High boost. Bet more money and turn on Nitrous
3. High boost and nitrous wins.. Collect money.
Blows their minds every time.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
This is very easy to do and tells a lot. Please start there.
Professional Hoon
Simpler, more reliable, less to break. Always the better way to go. Unless you like having 2 boost modes and nitrous as back up.
Because you never actually run all 3 at the same time unless you absolutely HAVE to. So many people "know" how fast you are. I laugh at them. Old school racers are evil. ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Pauly, as Sid says, you should just do the one Pressure line to the bottom of the Tial. - make sure it is a boost feed port and not a coolant port if you have the newer style Tial. See if it boost to 7psi and stops. Do not cap off top port. make sure boost reference line goes to Bottom port on Tial, not top. - Start there. If you only hit 7psi, then your problem is not in the turbo spool time, or wastegate size, or anything of the sort.
Professional Hoon
my log file didn't save so an unknown reason so i can't show anything ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
i ran spring pressure and its reaches 9.5 psi.
in single port mode all hooked up properly, it boosted the same, no difference on psi. And still it over boosted this time it was 19.7 psi because it hit boost cut on the DME.
Tomorrow i'll see why it's not logging and try again. but it feels the same single/dual port
Pauly, I got a little confused there. I apologize.
So when you ran single port on spring only, did it go to 9.5 psi and stop every time? - If so, then your set up is fine.. It's the electronic boost controller and or solenoid. (because clearly you are able to keep boost down to 9.5psi with that hardware.) - even if it's new. I hate the new controllers and their dinky little chineese solenoid boxes.
Or did it creep to 19.5 psi while set up in spring only? It seems you were talking about two different set ups and not just the simplest one on spring pressure only. - if so, double check the next question;
Additionally, have you changed out the springs recently? If so, did you make absolutely sure, and take great care to not pinch the diaphragm while tightening the assembly back together? - you have to constantly check as you thread each screw down. And, you have to screw each one down in baby steps. All 6 down 1/4 way, then 1/2 way, then 3/4..
I'm not trying to insult, I'm just making sure all the basics are covered. Other than the fact that pinching the diaphragm is one of the main causes of boost creep.
Professional Hoon
single/dial won't make a difference if you've got a EBC as you can set when the gate opens.
first of you're not insulting me, it's how you help so say what you have to say! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
okay i've never touched the spring or opened it!
i'll explain it better. what happens (both times) in 2nd gear when i put my foot down at around 4000+ rpm my turbo will spool quickly and the gate opens and hits over boost.
IT feels like the wastegate can't regulate the exhaust in the crossover quick enough. because i do it in 3rd 4th ect it's fine, just takes a while to get to full boost as i made it open at 12 psi so it creeps up to ~18.
If i try a MBC set to ~18 psi and if it doesn't overboost it's the eBoost2 and if it does overboost, would it be the wastegate?
first of you're not insulting me, it's how you help so say what you have to say!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
So to be clear, WITHOUT any other set up or using the boost controller, and just running spring pressure, (Boost hose to bottom of Tial)
You ran to 9.5 psi and stopped.. no more boost. You tried this at least 3-4 times and got to 9.5 psi every time without going over?
