Just to put things into perspective...
#31
On the Friday at least, it looked like it hit a wall down the straight. I mean a wall of resistance due to drag/downforce. Assumed that they'd wind in some boost to combat that. Certainly thought they ran more than 23psi during the weekend, but perhaps not? Duke, where did you read that?
#32
I'd expect they have maximised the downforce for the track, but even if it was running 23 psi it would be making a lot more than 4xx. It just looked to me that there was a lot more left in it.
#33
Thingo, the reason I say those numbers is for 2 reasons. I know the DSM's (evo motors) pretty well in varying states of Tune. (you should actually know this too looking at your sig) That psi (23psi) is a generality that points to 400's (extreme race set up) all exceptions aside.
I am also EXTREMELY familiar with 2300lbs and 406whp. This would be my car. extremely fast due to power to weight. A Large horsepower number had nothing to do with my quickness. I ran 124mph in the quarter with "ONLY" 406whp.
Using my Cars set up as an example; Drop 200lbs and add say 50hp. That is a HUGE difference due to percentages, NOT just face value of those numbers. 200lbs less than 2300 is almost 10% lighter!!!!!!!!!!!!!!!!!! Think about that.. Truly huge. 10% faster just in weight..(Not to mention the Braking and Turning advantages) NOW add 50hp. MORE than 10% more hp than my (old set up) car!!!!!! - I would add more.."!" to make my point even more dramatic, but I'm sure you get it. That would make him about 20% faster than my car was.. That is insanely quick and you saw an insanely quick car. It all adds up.
Numbers work out like this. NEMO: 2200lbs (with driver) / 450whp.(guessing) = 4.89lbs / hp. 95ONE; 2500lbs (me driving)/405whp = 6.17lbs /hp.. Almost exactly 20% more power to weight. That is a VERY fast car with the power and weight numbers I stated in previous posts.
EDIT: Lets make this comparable to a real world car From the Factory. 2012 Mustang. Weighs around 3650lbs. It would have to have 745whp to match the acceleration of the NEMO with only 450hp.
#36
