TonyG > New Race Car Build Thread
#151
Rennlist Junkie Forever
BTW... the red car in my pic will be for sale complete in it's totality minus the engine, headers, computer and engine wiring harness, transponder and seat.
Everything else is exactly as it is including cool suit, GPS lap timing, Chase cam dual cam pic in pic system, new 6 point Schroth harness, etc...
Street legal and currently registered. Spare splitters, S2 trans with 50/80 Guard Diff, 315's on all 4 corners, 996 GT3 brakes, Boxer ABS, Huge Radiator and oil coolers and diff cooler, 2725lbs wet, complete new front suspension including new custom valved and rebuilt Bilsteins, new porsche 968 control arms, new porsche spindles, new racers edge billet hubs, new racers edge rear control arm joints, etc.....
This car will kill 98-99% of anything on the track without being a trailer queen!
You only need the engine, RH headers, engine wiring harness. The motor mounts, dual 2.5" exhaust, the GM computer are included.
And.. you need a seat and your own transponder. Brand new Schroth 6 point harnesses are included.
TonyG
TonyG
#154
To find some kind of economy most people around here use used Porsche Cup car slicks.
#155
Rainman
TonyG
TonyG
#156
A couple more small updates.....
The Nascar door bars were modified and cleaned up.
The rear 996 shock mounts are almost done.
TonyG
TonyG
#160
Curious on the angle of the rear shock mounts. 996/997 mounts aren't quick perfectly vertical, but they are no where near the angle these are. Curious how that will affect shock performance. I assume you will have to use a slightly stiffer spring versus a setup that is more vertical? I assume they will modify the drop link mount so there isn't a severe angle where the link attaches to the shock?
#161
I don't know what they are doing for the drop links or drop link mounts due to the fact that they are building custom sway bars for the car (both front and rear).
TonyG
#162
Here's the rear shock mount finished. One of the 3 mounts was cut down and finished. Other two tomorrow.
Note the removable X brace in the roll cage :-)
TonyG
TonyG
#165
