Best Turbo For a Street Car
#31
Vitesse stage 2 turbo specs...... Oh, oh, can I try ?
How about a T04E 50 trim with a lightened comp wheel and maybe a few other mild mods mated to a turbonetics #8 replica with a stage III turbine wheel. Did I win ?
When it comes to Best Bolt on Turbo's - the three that come up most often are -
K27/6 or "Big 6" ( #6 with clipped turbine blades - similar to what powerhaus used to call their "Quick spool" )
To4e 50 or 57 trim / 8 stg III
To4b 60-1 Hi - Fi - / 8 stg III
Vitesse makes a street turbo that people seem very happy with, but we aren't 100% sure what it is, and John is keeping his intellectual property to himself !
I have the k27/big 6 and I really like it. Max boost at 3100 rpm on a 4th gear roll.
Call Charlie at Evergreen Turbo in Florida. He can hook you up with any of the above combinations.
#35
I had a garrett turbo built to meet the mods of my car. All should be matched up to obtain your desired plan in mind. Research and plan first, then buy.
#37
This Vitesse stage 2 might be what I need for my boat: I need between 400-450hp (450 with boost turned up, will be running E85) but has to spool quickly...a ball bearing turbo is probably a must for this very, very early spool requirement.
Mark
Mark
#38
Planning on running from the cops or something?
#43
Running from Coast Guard on the Colorado River, you guys are funny.
I hear Charlie does good work. Doesn't he modify turbos for powerhaus too back in the days?
#45
Hell, the one in the background could be pretty damned fast if he bolted a modern engine to it, as well. Mark, your project is dumbassed crazy! I LOVE it!
