Blown turbo...
Follow dnovak's thread. He's coming up with some innovative stuff.
https://rennlist.com/forums/944-turb...ghlight=dnovak
Other than that, if you don't have access to machining stuff modern stuff is out of the question.
Vitesse has a good, fast spooling turbo. It's pricey, but I've never heard of anyone complaining about the turbo.
You could try Evergreen as well. I have no experience with them, but I've heard they do great things with the stock turbos.
PS: 14 lbs at 4800 rpm sounds like you have a leak. More psi does NOT equal faster spool. It means a faster blowing headgasket lol. Pressure test your intake system. Listen for leaks. The exhaust headers on these cars are notorious for cracking. That would result in a serious lack of spool. You should be feeling the big '80's kick in the ***' right around 4000 rpm.
A k26 should get full boost much lower than 4800. If you want a true direct fit (i.e., able to use the stock j-boot and all) then look for a 'cheater' k26/8 turbo offered by Vitesse and others. You'll get more oomph with good spool. A good electronic boost controller will help you get the most out of that Tial too...
I figured the boost lag was a result in the turbo going bad, I'm seeing oil on the intake where the cold pipe meets. Prior to this I was achieving full boost at around 3800. Thanks for replies,
Ive been looking on the site for some information on the k26 cheater, can anyone enlighten me on the matter? I think I would like to go this route. Additionally, do you think my turbo spooling late because of configuration or intake manifold? I will have to take a look at that when time allows. Hmmm
I'm not interested in investing a lot of money into the car. I was rearended last month and the insurance totaled the car. I'd like to be around 280 horse and hit 1 bar around 3k. The engine was just rebuilt by European Autohaus.
