what pound springs are you track people running up front
Old 05-19-2012, 02:35 PM
  #91
Oddjob
Oddjob's Avatar
Originally Posted by White_951
Well, I'm shooting from the hip here, my set up:
400 * .8836 = 353.44 wheel rate
25.5 TB ~ 150 + 225 * .4225 = 95 for a total wheel rate of 245 rear?????
245/275 x18's BTW....seems like I need to bump the rears up to 500's....
Your existing spring rate balance (front/rear effective rate ratio) is not out of line w/ how most dedicated track 951s are setup up by experienced guys & shops.
Thanks for the responses...
...in my first test and tune a few weeks ago the rear springs were coming out of their perch's under hard cornering....
Not enough shared load on the coilovers, too much on the t-bars. How do you have the rear torsion bars indexed to work in conjunction w/ the coilover helper springs?
Old 05-19-2012, 05:20 PM
  #92
coilbox
coilbox's Avatar
Originally Posted by 333pg333
I'll have what he's drinking!
My ´86 has no LSD, my inside wheel lifts and have no traction coming out of tight corners. With higher spring rates and thicker ARB for sure it would be worse.
Just asking if you would consider softer springs in the rear to help traction without LSD?
Old 05-19-2012, 06:19 PM
  #93
333pg333
333pg333's Avatar
I was just having fun with what you'd actually written:
"How does a LSD o open siff change spring/strut rates?"
I'm guessing you meant to say:
'How does an LSD or open diff change spring/strut rates?'
Probably a fair question and assumption that you'd have more issues by going stiffer everything. Best answer is to get an LSD rather than work backwards. Picking up or smoking an inside wheel really slows you down and wears the tyres out too.
  #94
White_951
White_951's Avatar
Exactly what I was thinking...car was set up by PO so I'm not sure of the indexing....but the car handles beautifully, pretty much point and shoot...
Thanks!
Old 05-19-2012, 06:21 PM
  #95
67King
67King's Avatar
I'd suggest a limited slip. You don't need to lift for your inside wheel to spin, trust me - been there, done that, bought the T-shirt. A softer sway would help, but if you are really, truly lifting, i'd think stiffer springs would help because they would reduce weight transfer to the outside wheel, and they'd push the unloaded wheel down more. Weight transfer works sideways, not just fore-aft.
Old 05-19-2012, 07:11 PM
  #96
Skip Wolfe
Skip Wolfe's Avatar
Thanks!
Have you thought about ditching the tbars and just going with straight coilovers in the rear. Would highly recommend if it is primarily a track only car. It gives you the ability to tinker with spring rates easily and getting torsion bars correctly indexed and matched with the rear springs is very difficult - you are trying to get essentially two systems to work together.
Old 05-19-2012, 08:39 PM
  #97
White_951
White_951's Avatar
I'm thinking about it...
Is this just a matter of pulling the spring plates, removing the TB's and reinstalling the spring plates?
Old 05-19-2012, 09:29 PM
  #98
Van
Van's Avatar
Most people put in the elephant racing poly-bronze bushings when they do this... Do a search and I think you'll find a lot about it. (Like do a search in the 944 forum for "tiki torch")
Old 05-19-2012, 09:41 PM
  #99
White_951
White_951's Avatar
Yep...got em in my RS clone along with the monoballs....
Old 05-19-2012, 10:18 PM
  #100
Skip Wolfe
Skip Wolfe's Avatar
Yeah it is not the most fun job. Tedious but not too difficult and once it is done you don't have to worry about it again. And waaay easier than reindexing torsion bars.
Old 05-19-2012, 10:40 PM
  #101
White_951
White_951's Avatar
Yep...burned off plenty of rubber in my time....
I'm goin' for it....
Old 05-20-2012, 06:57 AM
  #102
coilbox
coilbox's Avatar
Got the joke now
Thanks for the info.
Old 10-08-2012, 04:55 AM
  #103
mattipuh
mattipuh's Avatar
Does the wheel rate / spring rate - values equal with newer ET car and older ET car in 944?
I know it comes all to susp geometry, but I have a feeling that older 944 has a different diameters in suspension in compared to newer 944, which would results in different calculation values to wheel rates.
and to the topic question.
I have 450lbs/inch fronts, wheels I use are ET67 with 5mm spacer so it equals 62mm. tires 255/35/18.
rears 700lbs/inch with ET44, tire size same 255/35/18
Old 10-08-2012, 01:47 PM
  #104
95ONE
95ONE's Avatar
I still see people using two calculations for the rear ratio. Its math and no one can agree to the same number? Weird. Arms are same dimensions for 86 or 87 and up.
Old 10-10-2012, 07:49 AM
  #105
mattipuh
mattipuh's Avatar
that's true. Well, exact figures are not so important, as far as it goes like **** and feels soooo nice. ,)
Quick Reply: what pound springs are you track people running up front
