getting race alignment done, need camber plates
Just found a couple threads re: camber plate reviews; thought some would find them interesting.
Ground Control vs. eBay
Racer's Edge vs. Lindsey Racing vs. Ground Control
so if I went with the GC, is it better to go top mounted? I would think that would give more room for adjustment? also, I would need a new strut bar. what works with the top/bottom mounted gc?
Rennlist Junkie Forever
You can't mount them from the top. They have to be mounted from the bottom. And there is plenty of room for adjustment. I would personally replace their lowish quality hardware with something of a higher quality in terms of the allen adjustment bolts. But other than that get a set.
Here's the trick.... get them and set them all the way positive (towards the fenders). Then align the car and set the camber to -1 via the eccentrics on the struts (at the bottom). Then dial in -3 degrees via the camber plates.
Make sure you get as much caster as you can get dialed in so long as it's the same left and right.
If you have rubber in your front suspension... set up 1/8 toe on the front.
TonyG
thanks tony. But GC sells both bottom mounted and top mounted plates. the top mounted are a bit more expensive. I'm just not sure of the benefits besides the $$ of either.
The factory sheet metal is the limiting factor.
And... just to be clear..... you can get pretty much all the camber you need without cutting on the strut towers.
TonyG
Again appreciate the advice. Think I'm going to get a set of the gc's. This car is just too nice to put some eBay crap on em. That's fine for the chump car, but not this race car
Ok going with gc. But they have several options regarding spring size and shaft size
I have koni yellow adjustsbles, but don't know how to answer those questions. Can anyone point me in the right direction?
TonyG
