I'm done!!!
#181
rennlist is being a little uncooperative, and I'm also trying to load straight to photobucket... that didn't work, so I just created an account on Flickr:
http://www.flickr.com/photos/61779132@N02/6973315128/
I will post the picture, those are some eat up bearings.
#182
First and foremost,all I heard about botom end was pistons look new,cylinder walls are fine. No noise,no ribrations. That being said,was car more out of tune on first three pulls? If that far out of whack why not stop until problem is fixed,was the 4-5-and sixth the tuning or hp runs? I'm confused,I was told car was ready before dyno? How,I mean if its that much out of tune?
#183
I apologize pernell. It's been a long week, and I'm doing my best to keep facts straight right now. We have nothing to hide here, and remember I volunteered through PM first to come in here and try to keep the community in the loop.
#184
Yes you did. And yes I can understand having to respond to a lot. As I said until all the facts are out I reserve judgement. I will come to shop next week to sort some of this out. Please know I will ask fellow RListers for input/help understanding somethings. Maybe I should have stressed more about making engine ready,don't know. Maybe you guys should have said it should've been done. The question is now what?
#185
From what I can see it looks like those bearings came out of an engine that had been run with coolant in the oil or extended contaminated oil.
Even if the boost is turned down the tune is usually spot on. Actually it tends to be on the leaner side. I'd look for another problem with the fuel system. It doesn't matter that these are larger injectors. This tune has been dynos numerous times and the results are always very comparable.
#187
#188
Regarding the rich running condition, of course we would like to troubleshoot the system, but without running the car, we can only do so much.
#189
Basic Sponsor
#190
Basic Sponsor
Good luck with this issue, sad indeed but without having all the facts it's difficult to make a full assessment. on others forums the approach is way different is not my problem, I should stay out, who cares, but the 951 community is pretty small and they ain't posers, I do believe that the 951 community above the rest of rennlist have some of the most talented group of wrenchers, techs, tuners, builders etc.
#191
How many miles would that take to occur? I have 3 oil change receipts from Arlington Porsche. That's less than 3,500 miles a change for the 10k miles.
#192
As the impartial observer to all of this, I for one greatly appreciate Dan replying to everyone and being so active in the thread once he learned what was going on. I'm not saying it's one person's fault vs another's but I do commend him for replying to the group as a whole. There have been a number of very aggressive and inflammatory statements getting thrown about and he could have easily done nothing and sat idly by.
Again, I don't personally care what the issue is or whose fault is whose. Just trying to offer some perspective in the hopes that some of us will try and remain calm throughout all of this.
#193
Also, given that the oil looked fine prior to the change and cylinders 1, 3, and 4 looked hunky dory, I would venture a guess that something is clogging the oil supply to cylinder 2.
#194
#2 bearing is a common failure point from oil starvation. Generally though, it will spin the bearing in the rod. It's unfortunate regardless. I certainly wouldn't point any fingers in this situation. I've seen way to many variables to be able to give a good enough assessment.
I'd say that it was a lucky catch if nothing else.
#195
