I'm done!!!
#166
Small Business Partner
Coding plug on or off?
If it was on the right mapping, then something else is wrong. Fuel pressure, MAP sensor, significant boost leak, ect.
That is off the-chart rich. Assuming everything is in working order, I expect the AFRs to be 95-97% on target right out of box. The AFRs being that out of order is a blazing flag that something isn't right.
#167
#168
Going with the pack
is quite monotonous.
I have a question.
The first chart posted shows a date of 4-24-2012.
The thread was started saying it blew up on the dyno on 4-23-2012.
#169
#170
The date on the computer is off. It was replaced a few weeks ago, and the person that came in and set it up was off by a day. We just never got around to changing it.
#171
Well, it's more than a bearing job. The #2 bearing spun, damaging the crank and the rod. The estimate given includes:
Remove engine/teardown
repair crank/rod
replace bearings
flush oil system(debris throughout oiling system, best to be sure)
new rings
gasket sets
and labor.
Our initial hope was that we caught it in time, and that there was no damage to the crank or rod, but that wasn't the case. If we are going to fix it, we want to make sure it stays together, plain and simple. Oh, and here's a picture of the bearing from #2
repair crank/rod
replace bearings
new rings
gasket sets
and labor.
#172
#174
What's up with those charts? Were they the ones where you were mid pull and shut the engine down? Weird looking hp and crazy rich afr's.
#175
I could see why this would be a problem if we were running lean, or if it was fouling out, causing a misfire, but neither of these things were happening.
The main reason for going on the dyno was not HP, but to set the boost levels safely in a controlled environment. After that was done, the next step was going to be to recording some HP numbers for the customer.
#176
Signing off of this thread for now. I will try and check it later tonight and over the weekend, but I have family obligations, so I can't guarantee. I will answer any questions I can as quickly as possible.
#177
Basic Sponsor
I dont like it, I finally had a chance to see them on my pc, I was using my phone at the beginning. nope, not only the date, also six pulls were done, the flat rich afr? I'll sit down later and transpose the data see if we can have a clear panorama.
#178
First and foremost,all I heard about botom end was pistons look new,cylinder walls are fine. No noise,no ribrations. That being said,was car more out of tune on first three pulls? If that far out of whack why not stop until problem is fixed,was the 4-5-and sixth the tuning or hp runs? I'm confused,I was told car was ready before dyno? How,I mean if its that much out of tune?
#179
Car was driven 20 miles when first delivered to you,can't be only 5 miles. Now I'm getting worried.......
#180
Drive-by provocation guy
You might get more answers and more information if you go talk with Dan and Ivan face to face. On here or emails etc a lot gets lost in translation. I know if it was me I would be up there at the shop in person to make sure everything is addressed and everyone on the same page.
