I'm done!!!
#136
Basic Sponsor
There are lots of reasons metal can be in the oil, what make them sure it is a rod bearing? I am off the the track to try and break my car and have fun..I hope things get worked out soon.
BTW: I have no experience with the shop in question, I just hate seeing accusations throw around without facts. There are several very good engine builders on the board, I would suggest you drop a line to Chris White. Always nice to have a second opinion.
#137
P5th. I think before you started this thread you should talk to them and figure out what happened. At this point there's a lot of speculation. I understand your fustration since I have been there already. I'm very mechanically inclined but I'm always affraid of blowing something. I spent ~7K at a mechanic just to do maintenance. After that I started seing things I didn't like + the attitude 1 one mechanic there that I told him to go F***** himself. After I received the car sometimes the car would shut off randomly. I had paid for new Porsche Speed/reference sensors, and I even replaced the other part of the harness even after checking continuity with a Multimeter. The problem persisted and after that I was in disblief that they broke the cable right by the sensor. After replacing it with a BMW sensor I have been shut off free for the last year. These cars are not that hard to work on. My biggest problem actually is not having enough height on my garage to put a lift. You have people by you that are very knowlegble like Joka and other people.Good luck, I hope you keep her.
#139
I have called,PM'd,Text messaged about dyno sheets.Maybe Dan just has not seen them yet? Don't know,I will give them benifit of doubt.Hopefully they will be up soon.Trying to stay positive.Just want car working is all.No not getting rid of car,have too many brand new parts still.
#140
Drive-by provocation guy
#141
I think I paid $10 for mine at a junkyard.
There have been a number of threads on the BMW S&R sensors. A search should tell you what you need. The only difference in the BMW sensors is the length of the lead.
#145
I'm going to assume that there was a mis-communication about what number is my personal cell phone, and which number is the shop phone, because my wife says that my celll is blowing up at home, but I haven't received any calls here at work... Sorry about that Pernell, let's see if I can get a copy of the dyno up.
#146
Don't take this the wrong way but why are dyno sheets so necessary to figuring out the extent of the issue?
More important than dyno sheets, I would be focusing on whether IMA are being communicative and if they are, what they are saying. This is an issue you and IMA should be dealing with, alone. If, after you have each had an opportunity to clearly vet the context surrounding the issues, causation, and perspectives on potential application of blame and you are unable to reach an agreement, then I welcome you to bring your case to RL and raise hell.
My concern is that you and IMA haven't had an opportunity to discuss things at length and may be jumping to conclusions. I really don't know either one of you all that well so my perspective is that you are both right until proven otherwise.
I'm very sorry for all this tribulation you've gone thru with your car; if you ever need a wrenching buddy I'm your man.
#147
#149
I have that sheet,no afr numbers and all of that. After sheets are posted this thread will close. I got more and more down the more I heard that day.Thats why I left,couldn't take anymore.Friday car was fine,Monday morning car was fine,monday afternoon car dead.That was hard to deal with for me. I left without them,just wanted a drink after hearing what happened.
#150
Remove engine/teardown
repair crank/rod
replace bearings
flush oil system(debris throughout oiling system, best to be sure)
new rings
gasket sets
and labor.
Our initial hope was that we caught it in time, and that there was no damage to the crank or rod, but that wasn't the case. If we are going to fix it, we want to make sure it stays together, plain and simple. Oh, and here's a picture of the bearing from #2
