Hybrid stroker project
#136
What a great thread! When my motor gives out I think i may definitely go this route.
Definitely try to get some in-car video mate. Jealous of your E85. If I'da stayed in AZ I definitely would've stuck with it. Meth injection here I come!
#139
Professional Hoon
Sid, i'm pretty sure i've asked you before but was are you using to control boost with? and are you using the 3bar MAP to log? if so how long is the vacuum like from the intake to the MAP sensor?
#142
I use an HKS EVC. It's an old 3 button with a manual ****. Actually tonight, the boost controller was off so it just ran on spring pressure. The line to the map sensor is probably 2 feet. from my logs it doesn't seem to matter how close it is. The only benefit I can see to having it close is to have it up above the possibility of oil running into it.
#143
Professional Hoon
Thanks,
I'm just trying to figure out how to make my loged curve flat like yours, where mine is jagged... even with a MBC and that actually falls off when i put it on.
#144
#145
That's very impressive so far Sid. What psi did you run your previous best on?
#146
#147
That's beyond incredible Sid! Essentially the same time with half the boost. Mind blowing. What can you put this down to?
You will definitely need something beyond street tyres next time.
#150
So to give an honest answer....
I think quite a bit of the gain was from the added mid range power of the added cubes. However, I think there is much more to be gained still and I can't lie. I think the lightweight parts, my cleaning up the combustion chambers (in shrouding the valves since I have a larger bore). Or there is another bit of work I did with the quench area that may turn out to be of great benefit.
We'll have to see what kind of power others make with my setup to see where the extra gains are from.
I do think that this setup has the capability to run over 120 at lower elevation, and I can't wait to ship one there
