If you had Boost by gear, how would you set it up?
Professional Hoon
I may have found a way to get boost by gear via my eBoost2
On the eBoost2 i can have 4 switches, each switch triggers a set point (boost setting)
so eg:
Switch 1 = 10 psi
Switch 2 = 14 psi
Switch 3 = 18 psi
Switch 4 = 24 psi
So how would you do it?
because there's only 4 switches maximum, 1 gear would share the same boost group. So which gears would you choose for which switch? with what psi @ what gear?
I believe if i find the right switches, i may be able to get the shifter to trigger each switch per gear selection by a custom bracket.
so eg:
Switch 1 = 10 psi
Switch 2 = 14 psi
Switch 3 = 18 psi
Switch 4 = 24 psi
Low boost 1st gear, slightly more in second, full boost third and fourth. That is how I achieved my best run using a single high/low switch from 12ish psi to 25 psi. I hit the high button at the top of second. With a good clutch you may get away with more in second but I doubt it due to tire spin.
Professional Hoon
I could go
1st = 10
2nd = 14 and creep it up to around 16-18
3rd = the full 25
What boost controller do you run?
Email Louis at GSS Speed Shop (formerly of LG Motorsports). I was friends with him in college in our car club.
I don't know the specifics of the 944 speed sensor, but maybe he could figure out a way to adapt his box to the 944.
http://www.gssspeedshop.com/Contact
http://ls1tech.com/forums/forced-ind...oost-gear.html
