on a dynopack wich is suspose to be 10-12 percent lower then a dyno jet i put down 299.8 wheel hp at 16psi of boost following mods -LR duel port, 55lb injectors, full 3 inch exhuast and 3 inch down pipe, and medium size garret about the size of a k27 not sure the trim size will upload the dyno sheet tonight
Without headwork I don't see how you'd expect more. The restriction is the same and until you really start cranking it up there isn't much that adds a lot of power. Turbo is efficient, tb is matched, ic flows enough and cools enough, etc...
That's good power for that boost pressure on a stock head.
