Anyone familiar with this knew high Zinc synthetic oil??
Hey Man
It would be nice if Amsoil actually listed the ZDDP content by PPM. Making a blanket statement that levels 'exceed API SM and later' only gives you the minimum possible value. It's probably a great oil but there are numerous other less expensive oils with published higher ZDDP content available than API SM.
i've been using it and it works great. that being said they have an oil specifically for older european turbo cars but i wanted to call and ask about the zinc content. haven't done that yet. i don't think you can go wrong with amsoil.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
was wondering about that when i saw the thread yesterday. no luck.
would like to see it as least as high as the M1 0w50 which has 1750 ppm P and 1850 ppm Zn.
Never heard of M1 0W50
The highest amount M1 has published (other than their race oils) is in the 1300 ppm range for their 15W50.
But their motorcycle oils are approaching the 1800 mark.
Tested samples of Racing Oils:
Joe Gibbs: 1010
Mobil 1: 1850
Brad Penn: 1570
Red Line: 2230
Amsoil: 1660
Royal Purple: 1100
Torco: 1130
Valvoline: 1520
Anything over 1250-1300 is generally detrimental. Real old stuff and air cooled bikes I think need more.
Joe Gibbs: 1010
Mobil 1: 1850
Brad Penn: 1570
Red Line: 2230
Amsoil: 1660
Royal Purple: 1100
Torco: 1130
Valvoline: 1520
Brad Penn Product Blackstone Lab
Penn Grade 1 zinc 1,214 ppm
20W-50 #7119 phos 944 ppm
Penn Grade 1 zinc 1,424 ppm
10W-30 #7150 phos 1,139 ppm
Brad Penn PCMO zinc 689 ppm
20W-50 SJ #7123* phos 522 ppm
The Amsoil lab tests for the ZRod are: 30 and 50 weight: Zinc 1440 PPM
Phos 1320 PPM
Also ZRod has detergents which make it good for the street. Here is some more info about it being tested after being used in a Mitsubishi Evo...
I ran 6.5k miles with 3 track days and it was still fine according to Blackstone Labs. I'll see how the new 20w50 will do with some hard track days and street driving. I'll do an oil analysis with 3 track days with 4k miles and see what they say. I thought 6500 miles and 3 track days was nuts. Blackstone Labs told me do 8k miles and 4 track days...lol. So for the 20w50, im gonna do 4k and 3 track days and see how it is.
Team Owner
their racing oil will protect turbos at cold startup better than 15w50 and yet retains 96 % of the viscosity at running temp. it has 1750 ppm P and 1850 ppm Zn. it's also been shown to be stable up to 500° F... i'm running 50/50 of 0w50 w/ 0w40 in my car.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Hmmm, I don't really believe any of that. According to that logic only Joe Gibbs, Royal Purple and Torco are 'acceptable'. What testing can you show that over 1300ppm is detrimental? Which lab are we using here? The test numbers you posted aren't right to begin with. Here are the lab results for Brad Penn for example.
Phos 1320 PPM
Phos 1320 PPM
