help car falls on its face
so my car has been choking up a bit when i was doing about 75 steady on the high ways it would so down and if i press the gas it does not even try go go any faster and the rpms dont increase does it for about a second not long and then its fine it did it every one and a while i changed my chips and recently put a map sensor and changed spark plugs and has not done it for the week it use to to do it once a day or so while on the high ways. so i assumed it was fixed since it had not done it for about a week and its my daily driver so today on the way from work a car rolled next to me i hit 2nd went into 3rd and it choked on me felt like i tapped the brakes hard for a second it fell on its face. after a second it was driving fine. please help thanks j brown son
Basic Sponsor
seems like overboost protection, maybe, check your boost line to the Cycling valve and to the wastegate, also inspect your CV
i removed my cycling valve and have the LR duel port WG . i also have MBC and have been running 18psi for a while and never happend just started to recently i though i might of had some bad gas or somthing bc the car runs great
If you used the Rogue Tuning chip and Map sensor check these two threads for guidance.
Miss-firing / Rich / no idle = Toe home Need help ASAP!
Throttle Position Switch???
Wow. That OP was two sentences. (with a small one at the end).
Try some caps, punctuation. People will actually be able to read and understand your post better, and will help you.
I had a very similar problem. My mechanic used some kind of smoke tester to test the vacuum lines and I think it ended up being a loose blow-off valve connection that would pop off a bit and dump boost but was intermittent. Problem went away after this was found. Fortunately it was a cheap fix once found. Good luck
thank you for your concern, but i did not know i said anything in my post about racing, and im 20 years old not 16. im sorry guys for the poor grammer i type so fast some times i miss things lol. all im looking for is some help for my problem thnaks
18psi i have been running 18psi for a while and never had a problem idk why it would be overboost protection ?. ever since i had the car i was getting 18psi and cooler days 20psi and never had a problem
