M-Tune on pump and E85
Is this a 'before and after'? Interesting how much higher your tq is over hp?
Yes, what mods and what, if any, were the other changes apart from M tune and E85?
Is that a boost of 16 lbs for gas and 22lbs for E85? That is yielding 67 more HP using higher boost or about 11 HP per lb of boost.
Nice numbers but I would run at least 93 octane for 16 lbs boost on gas. Interesting that the AFR were different by almost a point between the two runs at 6K RPM.
No, E85 is closer to 9:1. Also, you don't target stoich with gasoline, you target 12-13:1, depending on application (I'd target 13.0:1 for an NA application, 12.0:1 for a boosted application). E85 does not require as much enrichment for LBT, going off of memory.
But most people still run the wideband in gasoline mode, in which you can tune E85 using the same AFRs as for gasoline. ~14-15 for idle and light cruise and 11.5-12 at WOT.
Graphs are both after M-Tune. 16lbs. is on 91 octane and 22lbs. is on E85. Engine is built with Wossner pistons and rods,piston squirters,windage block,baffled pan,60-1 hi/fi turbo and 3" Borla exhaust.
Before the M-Tune my Lindsey 340 rwhp kit made 326 rwhp @ 18lbs. on 95 octane.
On the track oil temps were 210-220 at the end of a session instead of 250-260.
I still miss my old NSX. She was such a good Girl. Proper and polite when she needed to be, and was just Nasty when I pushed her hard. Good, good girl.
And that Hi Fi turbo is right about maxxed out. Mine was fairly laggy. Relatively speaking.
