Oil smoke from exhaust at idle
hey guys. Wanted your input. New engine, 400 miles on it, breaking it in per Lindsey Racing specs. At times there is some smoke out of the exhaust at idle that smells like oil. The turbo is new as well. I checked the oil on Friday and it was near the full mark on the dipstick. I'll check the oil when it cools down. It only does it every so often. I'm just wondering if this is to be expected during a break in?
Thanks,
Chris
Thanks,
Chris
Wow, seems a little strict. I'm at ~300 miles and have taken it to 6000 already (not really beating on it hard) and am currently running 7lbs of boost. Vacuum numbers at idle (cold/warm) are great (20 in/hg at idle, and 26+ on decel) with zero oil loss (now that the leaks are fixed), and she's running pretty healthy.
Since it was a Lindsey Racing engine, I went with their recommendation for break in oil and proceedure. If something did fail, I wanted to be in their guidelines.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Do a search on smoking turbos – its been covered as recently as 15 minutes ago!
On the good side – its not damaging anything
One the bad side – its not going to go away until you ditch the catch can – and your shop should have been aware of this issue .
