DIY Heat shield for the headers
I currently designed a heat shield for the headers of my 944 turbo. I made the shield out of sheet metal from "Lowe's" hardware store. Its very simple to make. Its a rectangular piece that measures 4.5" x 15.5" The piece fits right underneath that water pipe and bolts onto the exiesting holes that the radiator pipe already has. Here are a couple of pics
Should work good RAD
One warning, it looks like you have original fuel lines, check them well and double check the small hose on the front of the rail, there have been many fires caused by these hoses.
Yup, I have been meaning to replace them soon but always put it off. One question though, how do you get the hose off because its crimped on? Do you just cut it off? And how do you put a replacement hose on there??
I did the exact same thing about one mounth ago and am sure it does a difference in under hood temp.
I also plan on doing the same thing on the turbo side to help reduce the heat soak onto the intake manifold.Just waiting till i need to remove the intake for something else...
Hey,,a different heat solution if your interested; Jet-Hot coatings. I did my headers, turbo down pipe, and the intake manifold - the intake was done on the outside only, exhaust and turbo down pipe - inside and outside.
The cost was $134 for the exhaust, $80 for the intake, and $65 for the turbo down pipe.
I took temp readings before and after, the car had been run for 30-40 minutes, and ambient air temp was within 8° on the days the readings were taken. Taken with a laser temp gun, checked against my freezer gauge,,+/- 2°.
exhaust - before 486-500° @ the exit pt of the head. Afer Jet Hot - 296-310°
turbo down pipe - before 426-440. After Jet Hot 235-252°
intake - not much change, just a few degrees cooler,,but it looks great. What I did notice is that it cools off quicker after running the car.
I have put about 2k on the car since this was done and the headers still look brand new! The intake, I put bolts in all the holes, put bolts, washers, and nuts in the fuel injector ports; no problems.
Don't know,,,I'll be home in a week, let me get the guys name who I talked to - who took care of all my stuff. I have done business with him before...the intake and exhaust manifolds on my MasterCraft are done also.
[quote]Originally posted by StanUK951:
<strong>Isn't the fuel line replacement a recall?? My local Porsche dealer did mine in about 45 mins and for free!!</strong><hr></blockquote>
Was that not only the small hose on the fuel rail?
I had good results with a dremel and cutoff wheel discs.
Jason
Jason
Thanks for the tip! I just did this to my car today. It seemes to of helped keep the engine bay a little cooler. I still want to get my stuff coated in time I just plan to do stuff as it is off of the car for other reasons.
Tazman,
If the shield is vibrating, just bend the parts of the shield away from the metal that touches it. On mine, I made a horizontal curve bend downwards on the top section.
Anyway, Glad ya liked it.
