Turbo water keeps on running?..
Washed my motor bay today, and after that I noticed that the turbo chargers water pump was running;
I thought that its something to do with the moisture, or something. Started the engine, let it idle for a while, and shut it down. The pump was on for 20 sec, as it is supposed to, so no problem, I thought..
Just now, more than 5 hrs after the washing, I went to the garage, and what do you know, it was running again?
I took the pump relay away, so it naturally stopped. Put it back, and it kept silent.
Started the engine, and shut it down.
And the pump kept on pumpin and pumpin and.. <img border="0" alt="[grrrrrrr]" title="" src="graemlins/cussing.gif" />
So, what is the problem, bad relay, or some heat sensor or time sensor or or
it sounds like the relay needs to be replaced, if the problem was anything else the pump should have started up again when you reinstalled the relay. Sometimes relay contacts will stick until you remove the power source.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by David Floyd:
<strong>I think alot of us have made that mistake or I have anyway, ran my battery down.
All was ok after stuff dried out.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Same thing happened to me. Seems it was a couple of days before it operated normally again.
Ron
Ron
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by sybelix:
<strong>Washed my motor bay today, and after that I noticed that the turbo chargers water pump was running;</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Very common occurrence especially after washing the car. My turbo temperature sensor shorted out after a similar washing and had to be replaced with a new one. Part #930-606-118-00
Generally never the relay - but you can pull the relay to stop the pump from running continuosly
BTW, Try this first - Pull the old sensor completely, and give it a few hard taps, than re-install. Worked once for me – so you have nothing to lose.
I suspect once it shorts out you need a new one though.
ok. it's track day today, so it will propably be dry by the end of the day.. <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
But guys, thanks for the help
So yesterday was a track day, and we had a blast ! <img border="0" alt="[thumbsup]" title="" src="graemlins/bigok.gif" />
And as you guys figured, the problem is gone..
