How to drag race your 951...is it a drag car? :-)
#32
Those are some good 60 foot times really, especially if you are not using drag radials (which will help you immensely).
The biggest issue I found when drag racing mine was shifting (not sure if its a transaxle thing).
#33
#34
I havnt had any issues shifting using the two step.
This year should be pretty interesting considering I now have a clutch that is holding and that I will have a couple different power plants to test out.
I'm shooting for consistent 1.6 second sixty foots.
#36
Believe it or not there aren't too many vettes that can beat me up here even at high twelves. Most run low to mid 13's. I can only think of three that frequent the drag strip that are in the 11's. They either are pro charged or nitrous assisted.
I don't really care to compare to other cars much. I just want to run respectable times and see what I can do with it. Nobody at the drag strip knows how slow these things are anyway.
#37
Hi Sid, congratulations for the very good quartermile-time.
I think you use 275/40/17 drag radials ? What kind of rim is the best solution for this tire size ?
Sometimes i visit the quartermile with my 951. I use 10x16" Avon-Slicks (no drag-slicks) on
original 9x16" design 90 rims. This configuration performs also good (best ET 11,55 / 129mp/h).
Upcoming i will change to 17" drag radials at 9x17" rims.
Frank
Frank
#39
My car is a 944 Turbo model year `91. I drive the 951 since 20 years (only at nice weather) on the street and sometimes at the quartermile in Germany. Over the years i am are realized miscellaneous updates at the car. It is to much to list all Details (3liter-8V, KKK-Hybrid, HFM/MAF with Bosch DME/KLR & Apexi, KW V3 Suspension, etc).
But the transaxle, the gearbox and the axle ratio is completely original.
Therefore my interest above the drag radials at the 951.
#42
Pretty sure Sid has run about 11 sec flat now. Perhaps lower.
#43
Sorry about being MIA here. I've been having too much fun with my little 4g63 b210 datsun.
I use the 9" boxter wheels with 275 40 17s at about 18psi.
I have ran 10.80 at 134 down here, but it's just not as fun as going mid 9s at 143 in my little car, so I've semi retired the 944. I might take it again soon if I take the little one apart to do some more stuff. I think it will run a mid ten if I use some track prep. This track down here is not very good at prep.
To be honest though, I doubt I'll push it. For the simple fact that I'm just tired of breaking axles etc.
I think I have seen your car on drag times for a few years. Those are some great times!!
I just re read your post. I would use teh 16" wheels if I were you. I'd prefer to have more sidewall. So whatever size is equivalent to 275 40 17
#44
10,80 at 134 sounds very good. Instead you need also a lot of horsepower for this time. The boxter wheel`s are a good option. I will go to use 9x17 fuchs wheels (very light). But i hope the tires suit to the wheelhouse. Yes it`s not always fun with the 951 at the track. I have also many issue`s with the axle. Often the drive to the track makes more fun as the quartermile. Please see the pictures below.
