anyone install a filter relocation kit?
Canton make a nice cartrige filter that you can remove the top to replace the element. The body stays on and the oil in it that is easily siphoned out. I have one on my car and it is much easier to keep from making a mess.
https://www.pegasusautoracing.com/pr...p?Product=1283
Thanks great find
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
On my 968,I punch a hole in the filter, then I disconnect the oil cooler line from the cooler, and it drains the filter. It's a big PITA to have to deal with the cooler line every time but it prevents a mess.
On the 951 the cooler line is not as easy to disconnect (big compression nut as opposed to 2 small allens) so I haven't tried it on that car.
On the NA, I just clench my teeth and watch that oil gush down making a mess. I always wanted to drill and tap a drain hole on the side/bottom of the oil filter housing for draining out the filter... but I'd need some way of routing the spillage away from the engine parts. A brake bleed nipple would be the best, but I'd need a machinist to drill the right kind of hole for that. Still, it would probably be worth it.
I found
http://www.lindseyracing.com/LR/Pors...RP-25-484.html
But that's the damnedest thing... I swear they had an oil filter relocation (looked similar though, so maybe I mis-read), and it put the spot right where the fuel lines would go on a late Turbo... weird.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
