View Poll Results: Does your 951 leak?
No, it does not leak anything
29
31.87%
Yes, it leaks one or more fluids
62
68.13%
Voters: 91. You may not vote on this poll
Does Your 951 Leak?
Aint that the truth
LOL !! Good one David
I think I will win this one
Oil pan ( I think in more than one place )
Oil cooler
PS banjo bolt and pump
Motor mount ( yes they leak )
and looks like the RMS is leaking as well. Will confirm with resident expert tomorrow
Oil cooler
Late Porkchops
Leak ?
Leak what ? From where ?
This little red German bastage better not leak a drop. I spent a TON of money putting new everything in there "while I was in there."
Yes - oil and fuel
My mechanic said the majority was out of the cam box seal - surprised it doesn't sound like anyone else has had the same leak. New front main, cam box, and LR fuel rail / lines, and i'm hoping that's the end of it...for now
You better address the fuel leak before you drive it.
Mine was dry for a bit after I fixed the PS leak, now either my rear main or pan gasket has started to leak (and after only a year after replacing my clutch and rear main). There's a little seepage around the upper balance shaft housing but I wouldn't call that a leak (yet).
OK...I'll tempt fate. Mine was leaking like a siv up front. Had rennlister Phlip do a timing belt, rollers, water pump, etc., etc. and a complete front reseal.
No leaks...for now!
No leaks...for now!
