View Poll Results : Does your 951 leak?
No, it does not leak anything
29
31.87%
Yes, it leaks one or more fluids
62
68.13%
Does Your 951 Leak?
09-16-2011, 08:28 PM
Does Your 951 Leak?
Yes or no?
09-16-2011, 08:32 PM
It did... PS fluid. New set of hoses, rack, res. and fittings... SOLVED!
09-16-2011, 09:00 PM
Yes.
Turbo, oil pan gasket, oil cooler. Maybe more.
09-16-2011, 09:02 PM
Geaux Tigers!Rennlist Member
No. :knocksonwoodtwicethenspinsonleftfootandspitsinhand:
09-16-2011, 09:17 PM
Mine currently suffers from a bad oil pan gasket, took care of the rest.
09-16-2011, 09:37 PM
Professional HoonRennlist Member
i was going to start the same thread
rear main, sump bolt (oil drain), oil cooler and PS rack
09-16-2011, 09:42 PM
This didn't cost me any drachmasRennlist Member
09-16-2011, 09:46 PM
Oil and lots of coolant right now... I think my water pump seal went today. Waters dripping from from the side where the pump is behind the timing cover.
09-16-2011, 09:50 PM
09-16-2011, 09:59 PM
this is....a very dangerous thread..
09-16-2011, 10:07 PM
09-16-2011, 10:10 PM
AddictRennlist Member
I refuse to vote, so as not to jinx myself
09-16-2011, 10:28 PM
Mine leaks(ed) engine oil from two locations. The engine is out right now, and should be leak free after the reassembly.
09-16-2011, 10:32 PM
I voted no because if there is any sort of leak when I get my car back there will be hell to pay
09-16-2011, 10:48 PM
Addict Lifetime Rennlist Member
For almost 2 whole weeks, NO LEAKS... until the turbo came apart and a bunch of oil "leaked" out into the exhaust. Does that count? ;-)
But a new Super 53 now sits on my work bench... Got work to do!!
