How much do these V8 conversions really cost ?
#61
Thanks for the the offer 95ONE, I plan to weld and polish all the pipe once everything is mocked up and proven to fit. It'll be a while, to many projects in the shop!
Tony is right about the cost. $10k to $15k is a good budget number for a build. You can get a good motor and parts to go with it, You'll be at the upper end of that number for a performance type build.
He's right about the springs also, Like Xschop also pointed out, Stock or Z06 valve springs will not live long with a high lift cam. I install performance LS motors in all kinds of cars, I just put one in my 85' Dodge Truck for that matter. With an aftermarket cam with high lift we always change springs. Most stock spring land in file 13.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#62
Rainman
He's right about the springs also, Like Xschop also pointed out, Stock or Z06 valve springs will not live long with a high lift cam. I install performance LS motors in all kinds of cars, I just put one in my 85' Dodge Truck for that matter. With an aftermarket cam with high lift we always change springs. Most stock spring land in file 13.![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#64
You have to watch the used LS1 cams as the lobes can be fried. Get the Z06 cam from a 2004-2006 and yellow springs. The High end pull is amazing and you can stay in the Upper RPM's all day as the valves are lighter than the LS1 heads.
#65
Rennlist Junkie Forever
speaking of cams... I have my previous cam for sale at $200. It made 389RWHP on pump gas and has a nice smooth idle. It's the "old" MTI Stealth 2 grind.
TonyG
TonyG
#66
Pretty cool cam. One thing about the valve springs. Many people in the LS world run pretty high spring pressures for the RPM's, AND they run high lift. Those two together are hell on the valve train. (Not to mention improperly matched ones) It is pretty much understood on LS1-tech.com that you should change out your springs every year if this is what you are doing. So, yeah.. they break. I went ahead and shelled out some serious change for my springs just for this reason.
#67
I'm running aftermarket beehive springs with my cam.
I've been very happy with the work that Eric from Texas Performance Concepts did for me. Top notch service start to finish and a damn nice guy to deal as well.
#69
he released his long tubes like 2 months after i got the RH headers....I wasn't amused.
+4 for Eric though, great service and prices. After having met the ceo of RH i'm happy I had Eric finish up my swap(wiring, exhaust etc)
#70
Does anybody here have his headers on a cammed LSx engine with dyno sheet posted online?
TonyG
#73
Once you get to Tony's level of HP on this motor. Anything north of there starts to truly cost exponentially more. An extra 15hp.. its worth it when there aren't many other places to find power. And your HP fix is itchin to be scratched. The 'OLE Crackpipe of Speed is not kind. Been tryin to quit smokin it myself. .......eh... Not really.
#75
My best guestimate, based on before and after engine dyno runs on very similar engines, is that a Fast 102 intake/throttlebody is worth around 15Hp at the crank over that of a LS6/stock LS6 throttle body.
Why would I spend the money? Becuase of class limitations. Based on my weight (about 2675lbs), I can make about 440RWHP (depending on the actual race weight).
Given this... porting the heads would probably put me over and I'd have to tune the power out/weight the car down.
Another 10 at the wheels would put me close to 430RWHP. Couple that with a smaller crank pulley, larger air cleaner, MAF elemination, should get me very close to where I need to be.
I run in GT2 in the POC which equiv of GT4 in NASA (very very fast company). I defintely don't want to go over that. Going over puts me with 997 Cup Cars and full tube framed race cars, etc... Not good.
So in the end... I'm looking for another 20RWHP, and no more. Heads are a no-go.
TonyG
