turbo choices
#61
Silverbullet951,
When my engine is finished and broken in I will post the numbers from the dyno.
When talking to Majestic on choices, I asked for one that whould be able to support 425 RWHP @ 18 psi with the right combo.
#64
The calculations I made said you will be close to your goals at 6500 RPM 20# boost with a 2.82 engine...but that is really determined by how well the engine breaths.
There are also a ton of variables that need to be set to calculate the HP ,air temp, intercooler eff., turbo eff., VE etc., a change in any of these results in a change in the HP. You will have to Dyno the beast to see what you get. Looking forward to a posting on your results!
#65
Thanks for the info Beab951
Torque on this puppy should be in the 500 lb area also, so even close to these numbers should be fun for a daily driver
How is the Aussie wide band o2 project going? I have one on order and just received the o2 sensor from NAPA.
#66
I have it built but haven't had the time to test it. It went together with little effort and I REALLY need to get this wrapped up. I also have the parts to make a logger for the O2 vs RPMs vs injector duty cycle. I am sure it will do the job and will be cheap to build, just need for work to back off for a little bit, no more travel and the grass to stop growing a foot every week.
#68
I was trying to figure out what I have the 60 trim or the 60-1. I was looking at the Turbonetics price sheet and what do I find? Part# 20573 Compressor Housing TO4E/60-1, 3" inlet just as listed on my invoice, but I wonder what the difference is between 60trim and 60/1?
I am also thinking about a change to a #10 Hot before installing this new turbo.
Man, reading Corkey Bell's book puts plenty of thoughts in your head.
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
#69
[quote]Originally posted by David Floyd:
<strong>I am also thinking about a change to a #10 Hot before installing this new turbo.
</strong><hr></blockquote>
I dont think we dump enough exhaust, even with 2.8liters?!?! I dont think you'd even see positive pressure until 3500rpm's ? [quote]Originally posted by David Floyd:
<strong>Man, reading Corkey Bell's book puts plenty of thoughts in your head.
That's for sure!
That's for sure!
