Large Coolant Leak!?!
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Questions:
is this my water pump that has burst or just the hose?
does it even matter? i know i need to replace everything under those belt covers+ the waterpump and that hose anyways so maybe that is a moot question?
has this ever happened to any of you?
~Chris Lovin
All of the hose is separate from the water pump. You can replace that one hose and be on your way, but all of the other coolant hoses are the same age and could very well leave you stranded and with possibly a damage the engine. It's time to replace all of them.
Order a complete hose kit and get your hands dirty. It's a straight forward job. If you have never doen this before, take one hose off, match it to what is in your kit install that hose, and move on to the next.
This is good to hear, thank you for the reassurance. What fan shroud are you talking about? And where would you all suggest me getting the hose kit from? Should I just lump this together with the other maintenance I planned on doing? Thanks again. I feel like you just did half the job for me. As GIJoe would say knowing is half the battle.
Whether you do it all now or during future planned maintenance is really up to you. If the future maintenance means a couple of months from now, you're probably okay to replace just the one hose. If it means a couple of months, then put off to several months, then to a year and so on.... its better to do it all now. Besides, you're already going to have a coolant mess on your hands.
If you go the one hose for now method, I would suggest replacing the hose at the other end of the metal pipe, that goes over the header. It sees the same conditions as the hose that failed (high temperatures from headers, and no coolant flow when the heat isn't on).
Paragon, 944online, Lindsey all offer the coolant hoses as a kit. Lindsey brought a silicone hose kit to market about a year ago, which I've bought but haven't used yet. The long term durability hasn't been proven out yet, but will probably be fine.
Well I don't believe it would be down for two years to do hoses TB/WP and replace those AFR nightmare (autothority) chips but maybe you're right I'll probably find 800+ other things I need to do in the process. Whelmed/me
