New Product: MoMonitor Pre Release.
We will detect the limp mode based on the MAP sensor fault detection.
Knock/KLR related things are on my plate, a bit too early for full details.. Will elaborate when I have more details.
I know of a couple of racers wanting to overlay some data over the data collected by their track logger. Ex. would be When are you at WOT etc..
Another possibility will be to do a run, make some modification (like a cam), do another run and compare the results.. You'll be able to figure out the effect the cam had on the VE of the engine based on the air flow.. The software will also have a HP calculator etc...
Again, this is getting into the details which will require a user manual to explain..
I received a couple of questions regarding the difference software we offer. I'll address these questions here.
We originally had the base MAF software, then in 2008 we offered the V-FLEX upgrade which added boost based tuning. Recently we released the V-MAF+ which includes all of the functionality of the V-FLEX plus additional features and made it the standard MAF system. So the only available MAF system now, is teh standard system which includes all the features.
The V-MAF+ was released with the MoMonitor in mind, and it will support all the features of the MoMonitor. Earlier version of the software will support the MoMonitor, however some features may not be applicable.
If you have a Vitesse MAF software as on the chipboard (TM), the MoMonitor will work with it.
The MoMonitor works on the 951 and the 944NA as long as they are running Vitesse MAF.
John,
This is Tim, Kerry is installing the Stage II you sold me way back in June in my beat up grey '86. Provided this is compatible, I'm interested. Now that I'm up in NJ and away from my normal 951 support group in ATL, I need to be somewhat self sufficient. Besides, I definitely did not spend all I spent on my car only to run the engine at 90% efficiency. Seems that this sort of easy-to-read diagnostic would be just the ticket for me.
And getting to look at data in a CSV file outside of work is a definite added bonus!
Tim
Tim
The product will save me and the customers lots of time. There have been a few instances where I spent 20-30 hours assisting a customer (emails, phone calls,...) to find out the problem had nothing to do with the Vitesse products. As you can imagine, wasting 20-30 hours is no joy for anyone.. So yes, the MoMonitor will save time and will make trouble shooting much more efficient.
There are many customers that are not hands on or don't have the time to work on their car. They rely on their local shops for all repairs. The 951 is old enough, that many shops are not very familiar with it. If you check the shop rates to diagnose a TPS or a Engine Temp sensor, you can easily spend hours in the shop and $100s in labor. With the MoMonitor, you can perform the same 2-3 hours task in 5 minutes without opening the hood. It will pay for itself the first time you use it!
Think of the intermittent issues and of the amount of time it takes to track and solve. With the MoMonitor, you log till the issue appears. Then go back and review the data to see the status of all the variables and sensors at the time.. No need for someone else to monitor the gauges for you while you drive...
This reminds me of a customer who was not sure if he wanted to spend $1250 on the VR V-MAF+ kit vs. what's available on the market for $100 or so less.
I mentioned the user defined overboost and the rev-limit features as part of the safety features we offer. At the time, he questioned if he'll ever need the overboost as he's always on top of things. Sure enough, a few days later he called to tell me, in his exact words "You saved my engine!". Apparently, while on the track, the pressure hose to his wastegate came in touch with the exhaust and melted, allowing the WG to boost as hard as it can. There was no way he could have noticed it fast enough to react!
By setting the over-boost, the DME caught it and did not allow the engine to run over the user defined pre-set boost limit. So the extra $100 he spent to get the VR kit, saved him $5000-10000 (cost of a rebuild).
The same principle applies here, the $250-$300 someone will spend for the MoMonitor, will save them $100s if not $1000s, not to mention the time..
If there is enough demand to support the Metric system we will consider it.
Sorry for the long post, too much coffee this morning
