Cold air is fast air! (In the intake)
Old 11-26-2002, 12:59 PM
Russ Murphy
Russ Murphy's Avatar
Arrow Cold air is fast air! (In the intake)
Check this out!!!!! I see some additional speed in my future. <a href="http://www.designengineering.com/cryo2_related_items.html" target="_blank">Cryogenic Intake and IC sprayer</a>
Old 11-26-2002, 01:13 PM
blurry951
blurry951's Avatar
Post
Russ,
Are you planning to make an adapter (J-pipe) for this bulb piece, or do they (orsomeone you know) provide a mounting piece to the turbo?
Gabe
Old 11-26-2002, 01:14 PM
David Floyd
David Floyd's Avatar
Post
COOL !!!
Old 11-26-2002, 01:23 PM
Russ Murphy
Post
The aerodynamic shaped bulb goes inline between the intercooler and the throttle body.
This would work nicely for me since my air temp sensor is right before the throttle body.
Did you see the fuel cooler too?
Old 11-26-2002, 02:39 PM
MySwiss
MySwiss's Avatar
Post
Russ you may want to check this web site for good scientific articles including this one<a href="http://www.autospeed.com/A_1132/page1.html" target="_blank">autospeed.com</a>
Old 11-26-2002, 03:09 PM
Russ Murphy
Post
Interesting article. It seems like a large (square) sprayer bar with liquid CO2 might be pretty effective seeing as in this test they were dropping intake temps 8-9% with a single spray bottle. I think the real deal would be the inline cooler. They saw 30-35% intake temp drop on the turbocar with the pre-cooler temps a little over 100 F.
Old 11-26-2002, 07:29 PM
tazman
tazman's Avatar
Thumbs up
Looks good Russ! Did you find out what the prices are at all?
Old 11-26-2002, 07:54 PM
Russ Murphy
Post
The install kit (5lb tank, valve, stainless hose, acuator, full throttle switch, and other bits) will be around $375. The fuel rail cooling setup around $140. The spray bar kit $65 and the intake cooler $155. These are approximate retail prices. They should start shipping Feb. 1st.
Old 11-26-2002, 08:08 PM
Alan C.
Alan C.'s Avatar
Received 1,046 Likes on 538 Posts
Post
Might want to think about a little thing called Ductile to Brittle Transition temperature. Lets assume they did their homework and have their bases covered. Things like 409 SS have a DBT around room temp if the cross section is large coupled with large grains, like in a weld. Austenitics wouldn't be a problem at the stated temps.
Just something to be aware of when playing with metals and cold temps.
Alan
Old 11-26-2002, 08:14 PM
Russ Murphy
Post
So are you saying that the welds on the intercooler hardpipe might break if it gets cooled down sufficiently? Or the intercooler end tanks?
Old 11-27-2002, 04:40 AM
Olli Snellman
Olli Snellman's Avatar
Post
This is quite old trick.Back in the 70's we used CO2 ICE to cool down our Chevy drag racers fuel.
Old 11-27-2002, 11:36 AM
Russ Murphy
Post
Yes it is. But don't think it's ever been incorporated into the car in such an intergrated manner. Refilling an intake cooler with dry ice is ok between drag runs but not too useful anywhere else.
Old 11-27-2002, 01:02 PM
Alan C.
Alan C.'s Avatar
Post
Russ,
At the noted temps I don't think you will have any problems with aluminum. If you get 1008 carbon steel parts or some chrome molly parts into that range you could run into problems. Just a thought!
Alan
Old 11-28-2002, 02:39 PM
BoostGuy951
BoostGuy951's Avatar
Post
This has got to be the coolest idea.
C02 is probably the easiest gas to get your hand on too. I used to be into paintball, and I leased a 6 ft tall tank of that stuff for 50 dollars from a local distributor. Talk about bang for the buck!
Old 11-29-2002, 12:20 PM
Russ Murphy
Post
I'm trying to see a downside to this setup. Does anyone see any potential engine harm? I mean, what's bad about cool intake temps? If CO2 is cheap and the system is meterable so it can last a reasonable length of time, I think it's a winner. <img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
Quick Reply: Cold air is fast air! (In the intake)
