Home made int.cooler pipes + BOV
Sweet job, they look great! Is that a factory shape replacement elbow off the turbo (silicone of course)? Did you do the welding yourself as they look great.
Yes it is.
Compressor is 27 with 50mm output and pipe is 60mm. Hose is 50/60 with 45 degrees
few results ,1/4 mile: 5. Raimo Saukko, Finland. 8.627 @ 157.39 MPH old BMW 1502
6. Jani Lindqvist, Finland. 8.643 @ 157.09 MPH. old BMW 1502 (silicon seller)
Yes it is.
http://www.mandrel-bends.com/catalog...g-16-gauge-64/
I just ordered some SS exhaust stuff from them and it's good stuff. Going to be ordering some aluminum for IC pipes shortly.
Rocket Scientist
Pipes look nice. Some look polished and other parts of the pipes look clear anodized. Or is that just the picture?
Edit: Or nevermind. I see in the first picture some of the pipe isn't fully polished, than it is in the later pictures.
Columbia River Mandrel sells 16g 6061 Al pipe and bends (also have 11g 6061):
Ghetto why of making a bead: run two strips of masking tape parallel to each other with a < 1/8" gap between them. Apply a generous coating of JB Weld and remove the masking tape while the JB Weld is still wet, allow to dry, sand the high spots, add some paint, and voila you made a bead.
