which way should i go with this engine build?
So factor out back pressure being an issue for now. I'm just curious to know what the stink about running higher boost is, I'm not making a stink, just curious about the stink.
Small Business Partner
Boost is really more of a measure of restriction...
As Sid mentinoned earlier, a poor flowing setup at 20psi does not equal a good flowing setup at 20psi.
At any rate, my point is being missed. I was asking why guys don't like running high boost in these cars, yet it's ok to run 20-30psi through an Evo or something of the like.
Back on topic now...
Start a thread, I asked something similar in my 16v /2.5 thread. Our motor is 500cc's bigger than the 2.0 but it doesn't seem to make a difference on paper anyway.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Its pretty simple – 20psi @ 90f (an apple) and 20psi @ 250f (an apple flambé) are not the same.
You can run 20psi on a 944, even with a K26/6, just fine if you have tuned it for the right fuel/spark and just for brief periods. As soon as you mention the word ‘track’ it’s a completely different story.
The problem is heat. All sorts of heat. Not just coolant heat (that’s easy enough to deal with) but intake heat and oil heat. The intake heat is the killer for most 944 turbos. If you have a well-chosen turbo for street use it will not be at peak efficiency at 6k rpm and full load, and when turbos are outside of their peak efficiency they generate heat in the intake charge…and lots of it. Not unusual to see compressor outputs over 300f. the intercooler can deal with this for a while – but at track power level demands it will heat soak and the intake temps will climb until you get to detonation….and that’s bad.
So why do Evos not have this problem? Several reasons – the combustion chamber is less prone to detonation, the engine management is more modern/precise and the most important reason is that the typical Evo owner selects a turbo that is in its peak efficiency at very high boost levels – what we in the 951 world would normal call a dyno queen turbo! Not nice for the street unless you are a ‘boy racer’ that needs to hit 7500rpm in the grocery store parking lot.
BTW – here are some pictures of a ‘Hot’ Evo from last Monday at Watkins Glen – the only engine failure at an event with 170 cars.
The last picture is a butt ugly Mercedes – this one is uglier in person…..jut my opinion!
I consider it more fixing all that ailed it from the factory. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Wouldn't have gone this way except the motor failed, but once it did, it clearly was the best option for me and how I use the car. Financially too...
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
