My compression numbers after being towed home.
#31
Couple thoughts:
If the car was running fine, then shut off and would not start - that is most likely not a compression problem, unless the t-belt failed and it bent valves. If it was over rev'd to 10k on a missed shift, it might also have had some valve contact.
I have done the WOT testing with the car running on 2 cylinders. And I have burned an exhaust valve on track and ran a couple laps trying to figure out what was causing the drop in power. It would still pull 120mph down the straight w/ zero compression on #4.
I was also in the passenger seat of a 89T that broke a #1 rod on track, and blew the engine apart. It also had burned a #4 exhaust valve during the incident. The driver/owner had to turn the motor off with the key, because it was still running.
I would recommend checking all the common fuel and ignition failure points (DME relay, ign coil, cap and rotor, spd ref sensors, fuel pump, etc) before pulling the head.
Thanks for the input Jim. I'll look at it again.
#32
Remember, there are two TDCs... one on the power stroke (at combustion) and one after the exhaust stroke. For this second one, the intake valve will be partially open (remember, the intake opens a little before TDC to maximize the air flowing into the cylinder).
I think it's much more likely that you just have a blown head gasket.
Thanks for the Input.
#33
#34
If it isn't popping or trying to start, it sounds like ignition or fuel. Pull a plug wire and use the screwdriver to "near ground" to check for spark. If so, check fuel sys. Not sure why comp was low, but I think you have 2 different problems.
#35
It could be burnt valves – typically that would had a ‘chuffing’ sound at cranking since the area of the valve that is missing is fairly small you can hear the air escaping past it as you crank the engine.
Hearing the air in the intake during a leak down test would not be typical of a burnt valve – It’s the exhaust valves that get burnt.
I would also expect an engine with the compression numbers you listed to still start and run – maybe not very smooth but it should run and idle.
Sounds like you have something else going on….
#37
Also remember that you'll get a little leak-down past the rings, which will go into the crankcase, which will go to the AOS, which will go to the breather/PCV, which vents into the intake (j-boot) for emissions... This will cause air to be in the intake, although it's not getting their via an intake valve.
Thanks Van.
#43
Ok, as I was going to start taking the car apart I found that the lower part of the rotor came off. My rotor is all messed up at the tip and my cap is completly cracked the funny thing is that I had spark. I'll upload pictures later. Could this be the cause of a no start even with weak spark?
#45
Manny
