My compression numbers after being towed home.
Old 04-19-2011 | 11:52 PM
minho78's Avatar
minho78
Default My compression numbers after being towed home.
These tests were performed on a cold engine since it doesn't start:
Cylinder 1: 60psi
Cylinder 2: 130psi
Cylinder 3: 123psi
Cylinder 4: 95psi
Tests were performed with an Actron 7828.
I then tried a quick leak down test on cylinders 1 and 4. I got the engine at TDC and I can hear air escaping to the intake manifold.
What could have happened ?
Old 04-19-2011 | 11:57 PM
slap929's Avatar
slap929
Sorry to hear that. looks like you will be removing and replacing/recondition your head. Have you ever done that before? What caused the car to be towed?
Old 04-20-2011 | 12:17 AM
minho78's Avatar
minho78
It just stopped after pushing the engine.I have done it about 10K ago(~2 years). Hopefully I can get a rebuilt head for a good price.
Old 04-20-2011 | 01:10 AM
slap929's Avatar
slap929
what do you mean by "pushing the engine"? I saw a head floating around here not to long ago and at least you have done this before. Still sucks. Good luck.
Old 04-20-2011 | 01:44 AM
minho78's Avatar
minho78
Reving the engine in 3rd gear up to ~6000rpm.
Old 04-20-2011 | 01:50 AM
lart951's Avatar
lart951
Basic Sponsor
head did someone said recently rebuild head? $ 259.99 shipped, ceramic liners are intact no missing chunks
Old 04-20-2011 | 01:52 AM
minho78's Avatar
minho78
That's hilarious. I was just looking at it on ebay.
Old 04-20-2011 | 01:56 AM
lart951's Avatar
lart951
Basic Sponsor
last one I sold went for 204.00 plus shipping
http://cgi.ebay.com/ebaymotors/ws/eB...SA:MOTORS:1123
But it wasn't as good as this one, so you can bid if you wish
Old 04-20-2011 | 01:57 AM
minho78's Avatar
minho78
Lart you got PM.
Old 04-20-2011 | 08:41 AM
carlege's Avatar
carlege
did the T-belt skip a tooth?
Old 04-20-2011 | 09:25 AM
minho78's Avatar
minho78
I thought the same. But when I placed the engine at TDC, both marks line up. I'll have to double check everything when I have more time.
Old 04-20-2011 | 10:18 AM
MM951's Avatar
MM951
$260 shipped. I just spent $330 to get my head checked/valves cut , then another $50 on valves. Great deal
Old 04-20-2011 | 10:23 AM
reno808's Avatar
reno808
Thats a good deal.
Old 04-20-2011 | 10:30 AM
Tedro951's Avatar
Tedro951
When you say engine was "at TDC" for the leakdown test, you mean each cylinder was tested at "its" TDC, right?
Old 04-20-2011 | 10:32 AM
Tedro951's Avatar
Tedro951
A good deal, and once again, Lart was exactly 6 minutes in responding. Cat-like!
Quick Reply: My compression numbers after being towed home.
