My compression numbers after being towed home.
Basic Sponsor
Bummer... Let us know what you find. I would think the compression #s would be lower if there was bent valves. Also, if the marks line up, those #s wouldn't stop an engine from running. It wouldn't be healthy, but it should run.
Cylinder 4 probably would still run, but cyl 1 definately doesn't have enough compression. I was praying that it was either spark or fuel related, but unfortunately the compression test showed otherwise.
The motor will start and run no problem on 3 cylinders (w/ zero compression on the 4th). It will also run on 2 cylinders firing, not sure it will start - some of the factory diagnostic tests have you pull two injector connectors for WOT signal testing.
I would still look for a fuel or spark problem w/ a no-start condition.
Thanks Jim.
If the car was running fine, then shut off and would not start - that is most likely not a compression problem, unless the t-belt failed and it bent valves. If it was over rev'd to 10k on a missed shift, it might also have had some valve contact.
I have done the WOT testing with the car running on 2 cylinders. And I have burned an exhaust valve on track and ran a couple laps trying to figure out what was causing the drop in power. It would still pull 120mph down the straight w/ zero compression on #4.
I was also in the passenger seat of a 89T that broke a #1 rod on track, and blew the engine apart. It also had burned a #4 exhaust valve during the incident. The driver/owner had to turn the motor off with the key, because it was still running.
I would recommend checking all the common fuel and ignition failure points (DME relay, ign coil, cap and rotor, spd ref sensors, fuel pump, etc) before pulling the head.
I think it's much more likely that you just have a blown head gasket.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The difficult part is using the TDC at exhaust to intake phase – both valves are closed for only 4 degrees! (3 degrees Before TDC to 1 degree after TDC). Its much easier to rotate the engine 360 degrees and test on the TDC after compression.
>>>Looks like Van already caught that!<<<
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
It could be burnt valves – typically that would had a ‘chuffing’ sound at cranking since the area of the valve that is missing is fairly small you can hear the air escaping past it as you crank the engine.
Hearing the air in the intake during a leak down test would not be typical of a burnt valve – It’s the exhaust valves that get burnt.
I would also expect an engine with the compression numbers you listed to still start and run – maybe not very smooth but it should run and idle.
Sounds like you have something else going on….
Van clarified the reason I asked about TDC in each cyl. For a leak down check, think 8 TDC's....only 4 will work for the test.
Manny, this is where I was heading. Low compression in a few cyls wont stop an engine.
Also remember that you'll get a little leak-down past the rings, which will go into the crankcase, which will go to the AOS, which will go to the breather/PCV, which vents into the intake (j-boot) for emissions... This will cause air to be in the intake, although it's not getting their via an intake valve.
