Turbo and Boost for 500-550hp?
Old 04-13-2011, 08:20 AM
  #46
333pg333
333pg333's Avatar
Originally Posted by Thom
I always wonder how Alusil bores withstand lateral piston load when running more than 18psi... On a 3.0 engine cylinder pressure must be pretty high when running that much boost.
Stopping the cylinders moving has to be a good start Thom, plus increasing the size of the rod bolts to assist in clamping force can't hurt. Having said that, there are enough guys running over 18psi regularly on stock internals. Guess in the end it's always going to come down to trial and error unfortunately. Now with your standalone and J&S you have a lot of safety available. Should prove interesting and invaluable.
Old 04-13-2011, 01:02 PM
  #47
George D
George D's Avatar
Originally Posted by Wishmaster
Here in germany i drive 102oct ultimate gas.
SFR Stage 2 header, 3" downpipe, LR Intake
LR 3", Tial Wastegate
Checked with Dbilas Cam
PLX logging, Apexi duty, KS4 Knock, Haltech Map
Now i need only the perfect turbo I think about the GT35 or the Turbonetics gtk650.
Late spooling hmmm...Look at the charts here.
Do not buy a GTK650 for a 3.0 car.
Old 04-13-2011, 02:50 PM
  #48
Wishmaster
Wishmaster's Avatar
Can you tell me why?
Old 04-13-2011, 03:38 PM
  #49
Thom
Thom's Avatar
Too big.
https://rennlist.com/forums/944-turb...o-choices.html
Old 04-13-2011, 07:00 PM
  #50
George D
George D's Avatar
It's laggy as hell, and doesn't provide full boost on a well sorted 3.0 till about 4500RPM. We did see 530whp, but midrange sucked. We even installed a smaller hotside.
We are now using a Precision Billett 6262 with a .58 hotside and a few other mods done by Precision for this motor. This turbo begins to spool at tip of throttle and has full boost by around 3500RPM. Things happen pretty fast, so we won't know for sure till we have some dyno time.
We are installing another transmission, and we'll be tuning again next week. During static tuning, holding a steady 3K RPM and letting off the BOV opened every time. This was with no load in neutral.
Old 04-17-2011, 05:26 AM
  #51
nick_968
nick_968's Avatar
When you say full boost at 3500rpm, what gear is that in and what psi?
Old 04-17-2011, 02:40 PM
  #52
pole position
pole position's Avatar
I assume 4 th gear 16-18 psi but George will address that
you should give this Precision turbo a consideration, billet wheel, should bolt to the stock mount, need oil drain and downpipe/crossover mod. You also could go down to a 58 series If you want instaspool.
Old 04-17-2011, 09:50 PM
  #53
George D
George D's Avatar
It was third gear. This was the first boost run while tuning so we have a ways to go. These turbos are very well done.
Old 05-09-2011, 06:47 PM
  #54
blanco
5th Gear
blanco's Avatar
Can you tell me what happen? Did you go to the dyno? How is the turbo working? How many PSI? What RPM you got full PSI boost?
I'm trying to decide between a Precision 6262 or 5862 for 3.0 lt engine.
Thanks,
Old 05-09-2011, 08:21 PM
  #55
Black51
Black51's Avatar
This is OT, but hey blanco... Get some clear side markers and hand me the keys and you're done! Nice ride!
Old 05-10-2011, 11:17 AM
  #56
blanco
5th Gear
blanco's Avatar
I did change the clear side markers once, but did not work like the factory one.
Thanks,
Quick Reply: Turbo and Boost for 500-550hp?
