Turbo and Boost for 500-550hp?
Old 04-11-2011, 07:00 AM
  #31
Duke
Duke's Avatar
The EFR turbo's are huuge. Definately not possible to mount without custom mounting, downpipe and crossover. Since the EFR have inbuilt wastegate the turbine housing is much, much longer. You would have to change everything.
Edit: Sorry forgot the EFR is available without internal WG, but it's still a very large physical turbo.
This is how it looks with wg:
Old 04-11-2011, 08:40 AM
  #32
333pg333
333pg333's Avatar
Wow, they sure are long! Assuming the shape of the hot house is meant to be part of the improvements?
Old 04-11-2011, 11:39 AM
  #33
blown 944
blown 944's Avatar
Very interesting turbine wheel design!!
Old 04-11-2011, 11:41 AM
  #34
Duke
Duke's Avatar
Yes for those with internal wastegate. But even the turbine housings without wastegate are large and the center section and compressor housing are large too.
Old 04-11-2011, 11:43 AM
  #35
blitz951
blitz951's Avatar
Its said that the EFR7670 spools similar to the gtx3076 and makes power similar to the gtx3582.
Does anyone have any experience with this turbo or is it more internet/vendor hype?
Old 04-11-2011, 12:00 PM
  #36
Thom
Thom's Avatar
It would probably take a vastly redesigned 3.0+ 951 engine to push a GTX3582R within its full efficiency area.
Old 04-11-2011, 12:31 PM
  #37
blitz951
blitz951's Avatar
I agree Thom. I have a very modified 3L with all the supporting parts and still have doubts on the GTX3582. I have been waiting for my Tial hotside and my doubt keeps growing more and more. That said, a few people have used the GT3582 with the 3L and have been happy with the performance. I hope to get more info on the EFR as that sounds like its a good match.
Old 04-11-2011, 05:45 PM
  #38
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
this car project. best idea ever.
Old 04-11-2011, 05:52 PM
  #39
Duke
Duke's Avatar
Or a mildly modded 3.0 with lot's of boost hehe.
Seriously though, boost level is an extremely important part of the equation when selecting a turbo.
I feel a GTX3582R could be beneficial for my engine if I were to raise the boost to say 20 psi. Most 951 builds tend to run around 15-18 psi with a low rpm limit so a GT3582R might be too large for someone that prioritizes midrange instead of top end.
Old 04-13-2011, 12:51 AM
  #40
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I would go with a gt37r pick the a/r for you liking on a 3.0 I think it is not too big.
Need to know a few things where is your redine?
What do you have done to the 8 v head ?
Old 04-13-2011, 04:41 AM
  #41
333pg333
333pg333's Avatar
Agreed. From most things I've read on the limited use of the new GTX turbos basically everything moves to the right a bit but they respond to higher boost. Say 20psi minimum. As we see on other forums, 20psi is driving around the block looking for a parking spot. Many of these turbos are being pushed to 35psi + regularly.
I reckon one of the new GTX30s on a 3L would be very interesting with 25psi and E85!!!
Old 04-13-2011, 04:42 AM
  #42
Duke
Duke's Avatar
There is no GT37R. GT37 is not available with ballbearings.
Old 04-13-2011, 04:59 AM
  #43
Voith
Voith's Avatar
Originally Posted by Tedro951
I'd buy that guys Audi.
This is my neighbours car
http://www.youtube.com/watch?v=_3bdQmB3l0o
Old 04-13-2011, 06:10 AM
  #44
Thom
Thom's Avatar
I always wonder how Alusil bores withstand lateral piston load when running more than 18psi... On a 3.0 engine cylinder pressure must be pretty high when running that much boost.
Old 04-13-2011, 06:59 AM
  #45
Duke
Duke's Avatar
The weakest part of the chain always seem to come down to cylinder head sealing.
Quick Reply: Turbo and Boost for 500-550hp?
