Turbo and Boost for 500-550hp?
Old 04-10-2011, 02:31 PM
pole position
pole position's Avatar
Originally Posted by TurboTommy
No, you can also increase power by increasing the RPMs; keeping the torque from falling off at higher RPMs and keeping the pumping losses to a minimum.
Then you don't need as much cylinder pressure as you say.
The gt#s are a reference more for the compressor side, and just because they're either a little bit on the small side or the big side, that doesn't necessarily determine the power characteristics/powerband. That is determined more by the hotside. That being said, looking at compressor maps, only the biggest gt30s will flow enough air, on the compressor side, to accommodate the above power goals. Otherwise, a gt35 (I think the 600 crank hp is a misprint; they're all good for 650)
I am afraid you do not have a understanding of the four stroke Otto engine....raising the rev cealing will not increase output unless you incorporate major head cchanges which mandates a compression increase=cylinder pressure=power output or do you believe a 6:1 compression ratio engine will have high peak hp when you rev it 10 k ?
Old 04-10-2011, 02:39 PM
pole position
Originally Posted by Wishmaster
Here in germany i drive 102oct ultimate gas.
SFR Stage 2 header, 3" downpipe, LR Intake
LR 3", Tial Wastegate
Checked with Dbilas Cam
PLX logging, Apexi duty, KS4 Knock, Haltech Map
Now i need only the perfect turbo I think about the GT35 or the Turbonetics gtk650.
Late spooling hmmm...Look at the charts here.
If you have fab skills consider a external gated Borg Warner EFR 7670
Old 04-10-2011, 03:58 PM
Wishmaster
Wishmaster's Avatar
Does someone have installed a borg warner?
Old 04-10-2011, 04:07 PM
pole position
The new Efr are brand new so most likely not. On other platforms they are performing well.
Old 04-10-2011, 04:16 PM
333pg333
333pg333's Avatar
I was going to suggest EFR as well.
Yes, late spooling....compared to a normal modified 951. Not criticising, just saying.
Old 04-10-2011, 08:11 PM
JDS968
Bannana Shine
JDS968's Avatar
Do you know what that would be in (MON+RON)/2 rating?
Old 04-10-2011, 08:56 PM
DanaT
DanaT's Avatar
I have found that 98 European is equivalent to Super in USA (93-94ish).
From what i see 100 European is about 96 USA and 105 Euro is about 100 USA.
-Dana
Old 04-10-2011, 10:11 PM
thingo
thingo's Avatar
Which dbilas cam are you going to use?
Old 04-11-2011, 01:12 AM
TurboTommy
TurboTommy's Avatar
power = torque x RPM
your statement in your original post was:
"the only way you increase power in a Otto engiine is a increase in cylinder pressure either thru comp or Fi"
which by and large only affects the "torque" part of this equation.
Therefore I'm simply saying that your statement, as read, is a piece of misinformation. It's possible that YOU might not fully understand how power can be made in a IC engine.
Old 04-11-2011, 04:03 AM
333pg333
333pg333's Avatar
Can't see too much reference to Porsche on dbilas site? Do they make custom grinds? How about the throttle bodies and other such items?
Old 04-11-2011, 04:06 AM
Wishmaster
Wishmaster's Avatar
280°, spreading 114 / 11,7mm Ventilhub.
Do you think that the Borg Warner will fit on the OEM turboadmission?
Old 04-11-2011, 04:51 AM
MooreBoost
MooreBoost's Avatar
Wishmaster have you thought about using a 16v head?
Old 04-11-2011, 05:08 AM
Wishmaster
Wishmaster's Avatar
Yes, a few years ago. Now i drive my 3l Turbo 3 years and i think it was a good choice.
Old 04-11-2011, 05:10 AM
Paulyy
Professional Hoon
Paulyy's Avatar
IT dosn't say what grinds they have. just "sports grind" "race gring" ect ect. I'm guessing if you want something specific, they could make it up for you.
btw that avatar goes well with the 'You only live once Race Team!'
Old 04-11-2011, 05:54 AM
333pg333
333pg333's Avatar
Borg Warner needs custom mount or at least quite a bit modified OEM one. Not sure quite how different the EFR housings are from the previous version in terms of actual size and layout, but you can see that even on a modified OEM mount they come too close to the motor. It had to modified further to allow room.
Quick Reply: Turbo and Boost for 500-550hp?
