Hints on getting cooling hoses to seal?
Having problems will small leaks, in particular on the large end of the output hose from the water pump housing.
Any tricks on how you can get these to seal and not weep?
Unclear on the WP history - pretty recent via the previous owner. There is some sort of casting flaw on the edge of the pump right about where it leaks. I think this is part of the problem.
Hoses are new.
Good ideas...any solutions?
Hoses are new.
I wouldn't do RTV. I use a scotchbrite pad followed by cleaner on cruddy necks and outlets. Torque the clamp in small increments until leak stops, or clamp breaks. If the clamp breaks, go get another one. I recommend the "good" clamps from NAPA, or an aircraft supply place. There is a difference, but it probably wont make or break your leak.
This IS a new hose you're trying to seal, right?
