Anyone here use an Innovate Motorsports LC-1 wideband?
Wax On, Wax Off
if so, do you or did you ever have issues with an Error-8 (overheated sensor/ loss of sensor communication)? Particularly on deceleration fuel cut off? What'd you do to fix it?
I've read things from install the heat sink (on order) to downgrade the firmware version from 1.1 to 1.0.
TIA
TIA
Installed one on Monday with the DB gauge (which is too dim during the day... maybe defective) no issues so far. Mounted at 12 o'clock position right behind hanger flange.
TIA
TIA
Wax On, Wax Off
I have the sensor at the 10 o clock position in that little stretch between the downpipe, and where it curves to go along the torque tube... opposite where Lindsey Racing recommends putting it.
Sounds right, you should not see high temp or pressure at that location...I don't. Sounds like a defective unit to me. Also might be a cooked wire harness to the sensor, I did that once.
Wax On, Wax Off
Zeff, if that doesn't work, try the heat sink that Innovate makes. It's retarded expensive and metric **** ton of bull**** that it's not included with the kit, though TONS of their customers complain of the issue, but it solved my problem...
http://www.innovatemotorsports.com/x...cat=250&page=2
