Has anyone ever change a oil pressure sensor from the top vs the bottom?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I have a selection of ‘specialty’ tools – one of them is a 24mm wrench cut in half and ground down to be thinner.
There are a lot of other special tools that come in handy – buy a set of ultra cheapo wrenches from Harbor freight and have fun cutting them up as needed!
With a shortened 24mm you can do it from below without removing the PS pump.
POST #10 FTW!!!!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
It is an oil bearing part that is demonstrably broken. Compared to the endless hours you've spend "preparing" various parts for installation, changing that sender is a non-event. If you don't promise to change it, I may sneak into your garage in the middle of the night and put a new one on... Even if you have to pull the PS pump, its 3 or 4 bolts... Man up over there...
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Not lazy just pissed ... If I take off another f@#$ car part, that I have put on at least 3 times, I am going to loose my **** ... I feel like I have put this damn car back together at least 3 times already ..
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I have no qualms about taking those tools, and hitting them to the grinding wheel
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Actually, I kind of make it like a contest, to see if I can make it look like it came that way ... all polished up and such ...
Oohh.... maybe I should have said that ... I see a golden shower coming in my future
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Thanks Chris
I likey ...
I love the way he puts it in such legal terms !! ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Makes me what to go out and shoot myself for even entertaining the idea![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Hey, got a crows foot you want ground down![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
There goes another 100 dollars... I assume I should go with the Porsche one? ...
Yes, I must say it is hard to argue with Tom.....
Ya know, all his sense, winds up costing me a lot more cents ....
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Believe me, I would love to spend less than 90 dollars on it ...
I will ask around again... That's even cheaper than Pelican parts
best regards
Ed
Suncoast is usually the same price as the usual RL suppliers.... if you NEED an OEM unit
However, I do currently have the paragon unit on my car. Its only about 6 months old, but no problems with it. I did skip the rubber boots though.
