FS: Zeitronix
FS: Zeitronix
SOLD, thanks all...
$150, shipped in the 48 states.
This is the older version of the Zt-2, which was upgraded to the 2009 version by zeitronix. It comes with the widebnd sensor and harness, the 2009 Zt-2, and the LCD display (from the group buy way back when).
IMPORTANT DISCLAIMER: I replaced these parts with new ones because occassionally the A/F reading would freeze at 14.7. Zeitronix told me it was most likely a bad connection where the O2 sensor connects to the harness or Zt-2, or possibly the O2 sensor going bad. (I had previously replaced the O2 sensor for the same reason, and it continued to do the same thing, so more likely the connection plugs sometimes have a bad connection.) To be clear, it works almost all the time, but once and a while it will freeze at 14.7. You will need a new harness for the Zt-2 to wire it into your car, which zeitronix sells for $24, along with a bung for the exhaust, which zeitronix sells for $7.
i have one of these in my car and with the boost sensor and egt sensor, i have no need for any other aftermarket gauges in the car. The recall button works awsome for setting boost as well. GLWS
